Electric Vehicle Forums
-   Toyota Camry Hybrid (https://electricvehicleforums.com/forums/toyota-camry-hybrid-49/)
-   -   B gear? Do you use it? (https://electricvehicleforums.com/forums/toyota-camry-hybrid-49/b-gear-do-you-use-12980/)
titaniummd Apr 4, 2007 06:36 PM
Do you use the B gear? I just find it odd to release the gas and shift it to B to allow it to 'break'. Am I missing something here?
stevenvillatoro Apr 4, 2007 06:39 PM
Re: B gear? Do you use it?
I use it on downhills.
David Price Apr 4, 2007 07:32 PM
I live in WV and with all the hills that we have I've yet to find one that I can use the B mode on. It over does it on the grades we have. You either have to shift out of B mode or accellerate in just a few seconds.
nash Apr 4, 2007 07:40 PM
On long down hill grades I use B mode and set the cruise control. Just remember to shift back to D at the bottom of the grade. Of course the ICE noise from the high rpms will remind you after a short time, should you forget. :angel:
I find if I just coast in B, I loose too much speed on all but the steepest grades. I can use the gas pedal to moderate the effect of B, but prefer to set the cruise if traffic is light.
Sometimes in rush hour traffic, I also use B mode while the car is coasting down grades in EV mode (speeds < 18 mph or the ICE starts) and can avoid riding the brakes. I think it is safer as folks behind me see my brake lights when I do have to slow down, instead of seeing them all the way down the grade.
JHSmith Apr 5, 2007 02:00 AM
Uh, Nash,
I believe you may have erred about using "B mode" AND cruise control. Unfortunately, in the TCH, using B mode disables cruise control. :( (At least on my Japan-built TCH.)
Quiyst Apr 5, 2007 03:08 AM
I occasionally use the "B" gear, as part of my daily commute takes me over the Blue Ridge Mountains. Usually, though, I just lightly press the regular brake, calling the trip down the mountain "Regeneration Run." : )
nash Apr 5, 2007 07:56 AM
Originally Posted by JHSmith (Post 119571)
Uh, Nash,
Ops! You are right! I forgot it does that. I'm not sure if I'm remembering how the FEH works, or just flat out got it wrong. :embarass:
FL07THC Apr 5, 2007 08:38 AM
I have never used mine. I live in a pretty flat area though.
chris_h Apr 6, 2007 09:45 AM
In the 3 months I have owned my TCH, I have only used the "B" mode once, on a downhill. Glad to have it.
marklw47 Apr 6, 2007 09:52 AM
I've used it a couple of times, but I just prefer to coast down the hills and hope I don't get a ticket! I have a few great hills that make my MPG skyrocket when I coast, too bad I have to drive back home and ruin it all.
Mark
