Advise requested, "Low Engine Oil Pressure" MIL
Hello,
2007 Camry Hybrid. I received a Master Indicator Light (MIL) (Red Triangle with Exclamation) and the message "Low Engine Oil Pressure". I drove into a parking lot and while locating a parking spot the error cleared (no Triangle, no text message). I brought it to the dealer 30 minutes later and they said "No Codes in the computer error log". They don't know what the problem was if any. So I need some advise. Do I have an oil pressure problem? If yes, why was it not logged? Do I have a computer problem of some sort that raised a nonexistant error warning? Since there really was not error there was nothing to log? Sun spots? ;) I thought maybe a scan guage might track the oil pressure but on second thought the oil pressure of zero is perfectly normal for a hybrid as long as the engine is not running. Any thoughts/advise appreciated. J |
Re: Advise requested, "Low Engine Oil Pressure" MIL
check your oil level, if it's low then it will cause that MIL, otherwise it's just a fluke on the computer.
Oil level is fine. It was the first thing they checked.
So does the fact that a MIL was raised without a matching code being written mean something is wrong with the system? J |
An oil-pressure reading out-of-spec means one of two things. Either the oil pressure is low, or the oil pressure sensor is having an electrical problem. Either can be transient.
I would get a fresh oil change, and wiggle the wire on the oil-pressure sensor. Many electrical problems are caused by corrosion in the connections. Wiggling the connection abrades the corrosion. I do not know why a code would be displayed the operator without also being recorded. That does seem strange. |
Thank you.
Can someone give me a hint as to where the oil pressure sensor is located? 2007 Camry Hybrid J |
check this out
http://www.facebook.com/photo.php?fb...type=1&theater ask your dealer if they did a pressure check or you can do it yourself. yep an oil and filter change will at least relieve you of worries. |
Dealer checked the pressure and said it was fine.
Thanks all. |
Camry in an unusual attitude just prior to indication, or FAST/TIGHT low speed turn and sump oil "sloshed" to one side..?
To conserve energy many new cars are now using a variable displacement engine lubricating oil pump. If the Camry hybrid is making use of that technique the displacement control may have stuck in a low volume position briefly |
In this case the road was straight and level.
I was below 40 mph but don't know/remember if I was in EV mode or not prior to the event. When the low oil pressure indicator came on I believe the engine was actually running but may have just come out of EV mode but I am not sure of that. I think when (if ever) I get an answer to why/how I got the error indicator but it wasn't logged an actual cause can be determined. Tnx, J |
[2008 Toyota Camry Hybrid w/ 75K] I just had a similar incident for the first time. Driving 25mph on straight, level road in EV mode the 'low engine pressure' triangle lit up and the chime rang once a second before the engine kicked in. Since the alarm occurred while the engine was still off, I am chalking it up to a fluke. Oil was recently changed and is still showing full. The alarm has not occurred while the engine was actually running.
| All times are GMT -7. The time now is 12:07 AM. |
