Adjust valve clearance?
I have never attempted anything like this before, does anyone have the directions for adjusting the valve clearance or would I be better to take it to the dealer to have the valves adjusted?
:confused: |
Re: Adjust valve clearance?
Are you sure they are adjustable? Just going from memory, but I don't think they are.
automatically adjusted with hydraulic lasher adjusters.
why do you need to adjust them? if you have persistent clicking noise, tapping, as in rockers noise, run Seafoam through crankcase, to clean lashers. |
Oh, and 2007-2011 repair manual for non hybrids is out in stores. Same engine.
you put shims to adjust the valve clearance, better take it to a dealer if you haven't dealt with camshafts before. This is close to how it looks;
http://www.toyotanation.com/forum/10...mz-w-pics.html It;s recommended to check the valve clearance if the engine is developing a noise at 60k (part of maintenance schedule) btw "Seafoam" doesn't help, it could actually kill an engine (spun bearing) if used improperly. It's only used if the engine has a sludge problem due to overheating or neglect (no oil changes or bad oil) |
The hybrid engines have been modified from the conventional gas only. Sure that they have shims? I recall at least the 2012 has roller rockers, but that may be new.
That engine in the photos looks like it has a bit of a varnish problem. |
Originally Posted by Ron AKA
(Post 243817)
That engine in the photos looks like it has a bit of a varnish problem. For a car that's 18years old and 160+k miles, that is very clean. |
Originally Posted by lincolnshibuya
(Post 243821)
35 sizes of hydraulic lifters? What happened to automatic adjustment by oil pressure? And why do we have 96 engine even posted here?
Originally Posted by ukrkoz
(Post 243823)
