Electric Vehicle Forums
-   Toyota Camry Hybrid (https://electricvehicleforums.com/forums/toyota-camry-hybrid-49/)
-   -   6.1 VS 7.1 Nav Disk (https://electricvehicleforums.com/forums/toyota-camry-hybrid-49/6-1-vs-7-1-nav-disk-17739/)
KC Rusty Apr 12, 2008 08:26 AM
6.1 VS 7.1 Nav Disk
Before I update - are there any major differences between the 6.1 and 7.1 versions of navagation software. Is the update worth it?
Thanks in advance
WMConey Apr 12, 2008 11:01 AM
Re: 6.1 VS 7.1 Nav Disk
I noticed:
- Roads in my area now had street numbers [no refusal to give directions]
- Short warning screen that turns itself off
- New split window that shows upcoming exits with icons for what's there
Worth $250? No. $50? Maybe
Regards
nyceshirtz Apr 12, 2008 12:19 PM
Are any 2007 TCH's running the 7.1 Nav disc?
WMConey Apr 12, 2008 01:42 PM
My comments above were from borrowing the 7.1 disk out of a friends 2008 TCH and inserting it in my 2007. Most interesting was that I didn't have to pull a fuse to reset to the new software. I got a "trying to read disk" message, then "reloading" and Viola, new software. After giving back the new disk and reinserting the old, I still have the new nav system running, as evidenced by the disappearing warning screen on startup.
nyceshirtz Apr 12, 2008 05:44 PM
even after powering off and powering on the car?
schmidtj Apr 12, 2008 05:50 PM
Newer firmware loads automatically. To downgrade to older firmware requires powering down the NAV (pulling fuse etc.). If you swap back to an older DVD you have the new firmware and OLD data until you power off the NAV. Enjoy the obsence of overrides the 7.1 DVD gives you and OLD data of the 6.1 DVD. You have the worst of both worlds it seems.
schmidtj Apr 12, 2008 05:53 PM
Thanks in advance
The I agree screen goes away automatically after a few seconds as previously mentioned. Also some newer roads in my are that were missing the the 6.1 DVD are present on the 7.1 DVD so the maps have been updated.
All my preferences were reset but it saved my previous locations and memorized destinations.
WMConey Apr 12, 2008 06:25 PM
Since I don't use the overrides, from my perspective I only lost the need to push an "Agree" button. So I came out ahead from my perspective.
And yes, the new firmware "sticks" through a power cycle.
delao13 Apr 12, 2008 06:49 PM
Originally Posted by WMConey (Post 168219)
I noticed:
Do you mean you don't have to press the OK button to get the warnings to go away?
schmidtj Apr 13, 2008 04:28 AM
Power cycle (as in turning the car off and on) yes. Power cycle and in removing the battery or NAV Fuse, NO.
You also have the OLD road/poi data which is not stored in the NAV but read from the DVD as needed.
