2013 TCH, Remove 6" screen and install aftermarket Nav?
Hi all,
I'm considering an XLE Hybrid 2013, is it possible to remove the stock radio and install an aftermarket 2Din unit? Which features do you lose if it is possible? Thanks in advance. |
Re: 2013 TCH, Remove 6" screen and install aftermarket Nav?
Everything is possible.
Mof, let me dig this out for you: http://www.oemcargps.com/toyota-camr...-c-98_787.html Someone else suggested this: http://www.adventproducts.com/oe-mul...s/?sku=OTOCAM2 This is all dandy, but what you will lose is all data available via OEM nav system. Surprise. That's s/w compatibility issue. They can have all the right plugs and connectors, but aftermarket nav unit will not "talk" to the onboard computers, and you will have nothing more but a fancy radio. And some of that info you DO want to save, like logging into diagnostic mode, eg. |
