07 camry hybrid system display arrows
the arrows in the dash display that give direction from the batteries and engine to the wheels and back are starting to stay on and off when they should not . my battery level display stays high and doesn't show any drain . the car drives and feels normal , but something is amiss . i took the car to toyota , they kept it for a day and said nothing is wrong . i've put 240,000 miles on the car since i bought it new . any ideas ? thanks , nich
Re: 07 camry hybrid system display arrows
There are several things that could be the problem, BCM, ECU, wiring harness, dash display unit, corroded connections and a multitude of other issues. Personal opinion? Drive it until the display is wrong ALL of the time and then take it to the dealer. That way they have a problem they can't deny and should be able to track it down.
Originally Posted by nich
(Post 246865)
Hi Nich,
Have you find what is wrong and fixed the the problem? My car has the same issue at 220 000. Dantcho |
