Re: 07 Camry hybrid / first tank a gas
Originally Posted by Burt Bochner
Thanks for the tip nowhere to buy my phones but I think my problem with my phone is that its first generation blue Tooth not the new 2 nd gen. anyways I was impressed by your photo songs could take some but naive beat you do at time that taillight photo is great !!! I didn't realize my taillight's look so good! I knew I had the LED tail -lights but I didn't know what they looked like! Anyways I wanted a ash to a question to see maybe you have a cure for this problem, I find that all the 12 volts outlets turn off when you in the ignition goes off so my eye potted doesn't get charged to my cellphone doesn't get charged I've gone to electrical car or people likes a stereo shop and they said they won't touch it because it's a hybrid! All I wanted them to do was convert my outlets to being on all the time. To have you had any such problem with the way you use electricity in your car? This is my first response ever to something that I have posted please disregard anything as far as grammer are or things spelled wrong because I am a terrible typists I am I am using a voice recognition program. They say it has a 95 percent accuracy I think it is probably around 97 percent accurate. Anyways if you have any suggestions about so finding someone to switch my car over to 12 volts being on all the time please let me know.
BB cableguy I think 95 perscent accuracy might be just a little bit on the high side. |
I'm not sure that having the 12V outlets on all the time would be a good idea. My husband has set his XM Roady to turn itself off after an hour, because his Jetta doesn't turn off the power to its "cigarette lighter" and I think you can drain the battery by leaving the Roady on all the time. My Corolla, on the other hand, shuts off when I turn off the car, so the Roady doesn't drain the battery at all.
BB cableguy |
Your are right! I talked to toyota today! tThey said that if I run power to my I pod that dosen't turn off with the ignition switch it could voaid my Warr
Glad I could point that out before you did something that might cost you a bunch of money later. I'd be hesitant to let someone who doesn't know about the hybrid's electronics (and high-voltage) tinker with it.
