Electric Vehicle Forums
-   Our Announcements (https://electricvehicleforums.com/forums/our-announcements-8/)
-   -   Hybrid Mileage Database: Achievement Records (https://electricvehicleforums.com/forums/our-announcements-8/hybrid-mileage-database-achievement-records-474/)
Jason May 15, 2004 02:17 PM
A new section of the GreenHybrid real mileage database has been created to recognize those with extraordinary achievements for their respective vehicles. The Achievement Records now display the most efficient drivers for both lifetime and single tanks as well as those with the farthest distance on a tank.
Congratulations to all who are currently on the list, and good luck to those who will soon overtake them! :D
Stevo12886 May 15, 2004 03:02 PM
hey jason, didnt xcel want to get that 114 mpg run off the record as it was somehow an overfilled tank?
Jason May 15, 2004 03:04 PM
Beats me. People overfill tanks all the time. Unless he literally filled it up after it expired, I'd say it counts.
Hot_Georgia_2004 May 15, 2004 05:44 PM
This is a great database feature.
xcel May 16, 2004 09:00 PM
Hi Jason:
___Yes, I posted this issue in another thread … The two tanks when averaged came out to be 92.5 mpg IIRC. The range record however might be broken by Wednesday/Thursday of this week with some hopefully warmer weather here near Chicago in the next 3 days :(
___If I replace the two calculated with the average of the two in both, this should knock the records back into line hopefully?
___As an edit, I just changed both of those tanks to 92.5 mpg instead of 75 and 114 to match the average between both … Now my 1,228 miles on a single tank does not register as a the longest range on a single tank? By midweek that will probably change anyway but the range achievement(s) appears to be messed up a bit given what is showing for the farthest distance Insight in particular currently.
___Good Luck
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
Jason May 17, 2004 03:11 PM
Wayne,
I'll check it.
Jason May 17, 2004 03:53 PM
Wayne, fixed!
The problem was that for the tank distance & mileage tables, they essentially use the same code. I simply say to search for one or the other. Because of this, I used the same variables and the second table was reusing the old member data (oops!). So, I unset the variables before they got to the second section.
xcel May 19, 2004 05:29 PM
Hi Jason:
___The Insight tank that would never end … Finally came to an end ;) SOB that was a long way!
http://barnson.org/albums/album06/Re...ed_Resized.jpg
___Good Luck
___Wayne R. Gerdes
Jason May 19, 2004 06:04 PM
Wow! Congratulations on the new record.
Stevo12886 May 19, 2004 08:58 PM
nicely done wayne....i wouldnt have the dicipline to drive it in mpg form for that distance
