New Clutch?
Toyota's website for the 450h mentions a new drivetrain that has 2 clutches, an inner one and an outer one, each capable of interfacing with the wheels. Since the Lexus still seems to use a Power-Split-Device (from the Prius), which seemed to eliminate the issue of a clutch, I'm surprised to see a clutch - let alone 2 - in this car. And knowing Toyota, if the clutch is back... it's probably not a typical clutch.
Anyone have any info on how it works? |
Re: New Clutch?
The drivetrain has dual speed reduction gears between MG2 and the ring gear of the PSD.
The clutches are used to switch the gear ratio. Ken@Japan |
Re: New Clutch?
Are they typical clutch plates? Or something fancier?
