Toyota Hybrid Police cars (long article)
Hybrid Police Cars http://www.pfmmag.com/images/spacer.gifhttp://www.pfmmag.com/images/spacer.gifBy Christy WhiteheadPolice agencies around the United States are buying hybrid police cars to replace gas-guzzling counterparts and save taxpayers' money. Hybrid cars like the Toyota Prius and the hybrid version of the Honda Civic average 50 mpg compared to the 16 mpg of the current law enforcement workhorse, the Ford Crown Victoria. Martin County, FL, Sheriff's Department Sgt. Jenell Atlas said that with gas prices for government currently at $1.02 a gallon, the southern Florida county is expecting to save $6,000 per hybrid car purchased. How It Works Unlike the pure electric cars that were first introduced in the United States, the hybrid vehicles of today never need to be recharged from an external source. Hybrid cars combine a gas engine with an electric motor to create an environmentally superior, fuel-efficient vehicle that never needs to be plugged in. To heighten system efficiency, hybrids are fitted with a regenerative braking system that allows them to generate their own electricity. When the vehicle is subjected to stop and go traffic, or the brakes are applied, the motor is turned into a generator. The motor captures energy that would normally be lost as heat or kinetic energy and transforms it into electricity to recharge the batteries. Hybrids use nickel metal hydride (NiMH) batteries, which have the same recharging technology as that used in Palm Pilots and cell phones. The hybrid will run off the electric motor when running at slower speeds or in stop and go traffic; at faster speeds the engine takes over and powers the car. While sitting at a stoplight, the hybrid shuts off altogether. The engine instantly restarts when the driver pushes on the accelerator or puts the car in gear- with no lull in momentum. The engine will also run when the air conditioning is turned on or if the battery needs recharging. An in-dash monitor tells the driver whether the car is running off of the motor or the battery. Global positioning systems can also be installed so maps can be displayed on the screen as well. The Toyota Prius comes with a Continuously Variable Transmission which keeps the engine running at its optimum power range. The CVT also allows the car to get better gas mileage and be more efficient. Honda offers the CVT transmission as an option rather than a standard feature. (The Honda Civic Hybrid can also be purchased with a manual transmission.) Hybrid cars are designed to be treated as conventional vehicles. The batteries are designed to last the life of the vehicle and do not require replacement. Toyota and Honda both offer eight-year warranties on all hybrid-related parts in the car in addition to any standard warranties. Toyota's warranty covers up to 100,000 miles, while Honda's warranty covers up to 80,000 miles. A Department Money Saver Many police departments are switching over to hybrids in the hope of saving money over the life of the vehicle. Atlas, of Martin County, reports that the use of hybrids has dropped the county's fleet expenses by as much as 65%. Wyatt Earp, director of fleet management for Marion County Florida, has purchased several Toyota Priuses in an effort to cut his county's expenses. Earp said he sat down and tried to set up a reasonable life cost analysis for the hybrids in comparison to the police cars they were replacing. When he looked at the life cost analysis and data from other government agencies that were using hybrids he found that everything "just made sense." Marion County purchases around 45 new cars a year for its fleet. Earp plans on evaluating his current fleet to see where a hybrid would be much better suited for the job than the bigger, less fuel efficient cars. Major Patti Lumpkin, of Marion County, estimates that for each hybrid the department has purchased it will save $5,000 over the life of the vehicle. Earp said that while the cost was a little more for the hybrid up front, he expects to save money over the long haul of the vehicle. Toyota is also covering some of the routine maintenance of the car. Earp said that at this time he has not invested any additional money into the maintenance of the cars because of the routine maintenance that Toyota provides. The warranty on the hybrid technology was also a big factor in Marion County's purchase of the hybrid technology. It has allowed the department to try out the technology without having "to play a guessing game with taxpayers' money." The county plans on using each of the cars for about six years; Earp says that at about that time the Priuses should be running at 100,000 miles and the warranty coming to an end. While the hybrids don't quite have the pickup desired for chasing speeders, many departments are finding a niche for the cars where the beefier engine is not required. The hybrids are ideal for serving warrants, delivering subpoenas, and running administrative errands. Marion County has designated two of its Priuses as homeland-security cars. Trained civilian volunteers use the hybrids to inspect public facilities, which might be susceptible to terrorist attack- a job that requires lots of time on the road. "The hybrids are clean and sound, they are a good investment," Earp said. The great-great nephew of the gunslinger of old West lore explained that his obligation to taxpayers is to conserve as much energy as possible and to spend their money wisely. Earp initially purchased four Priuses in 2002 to test them out. He has been happy with their results and he plans on purchasing 12 more of the vehicles this year. Earp also has plans to purchase some of the new Honda Civic Hybrids, which just recently became available for purchase. More Than Just Cars The hybrid technology is also expanding into SUVS and trucks. Some of the domestic companies like Ford are planning on putting out their own hybrids in the near future. When Ford puts out its Escape Hybrid this year, Earp plans on buying some for his fleet. The four-wheel drive SUVs would allow Marion County to use hybrids in a broader spectrum of jobs than they are currently being used. J.D. Power and Associates said that automakers are planning on introducing a dozen new hybrid models over the next two years. Sales are expected to be at 177,000 units annually by 2005. According to HybridCars.com several American companies are planning on jumping on the bandwagon and offering hybrids this year. According to HybridCars.com, these models should be hitting showroom floors this year: Dodge Ram Pick-up, Ford Escape SUV, GM Silverado Pick-up, GM Sierra Pick-up, Lexus Hybrid SUV, Toyota Highlander SUV. HybridCars.com also stated that several other hybrids are slated for production in the near future: Chevrolet Malibu Sedan, Chevrolet Tahoe SUV, GMC Yukon SUV, Honda Accord Sedan, Honda Pilot SUV, Saturn VUE SUV, Toyota Camry Sedan. Electric Vehicle in Comparison to Hybrid Marion County also owns 12 completely electric vehicles. Earp's department uses the electric vehicles- which look like space-age golf carts- for community and school patrols. They are also used at events like those held at their fairgrounds. Earp said the vehicles are fast at about 25 mph and good for the environment. The electric vehicles, which the department has nicknamed NEVs or Neighborhood Electric Vehicles, have one drawback in that they have to be charged every night. Earp has found the NEVS not to be as practical as the Prius. "The hybrid, now that is really a viable alternative," Earp said. "Plus with this [the Prius] the taxpayers get something back." Environment and Community Friendly Farther south in Martin County, hybrids are replacing less fuel-efficient counterparts that are unnecessary for certain jobs, like detective work. Martin County figures that for every Crown Victoria it replaces it saves the county a little over $100 a month. The county currently owns 11 Priuses and four Civic Hybrids. Sheriff Robert Crowder hopes to buy at least 50 more hybrids in the next year or so. Crowder's department was the first law enforcement agency in the nation to implement hybrid cars into its fleet. "It is the right thing to do," he said. "We must decrease our dependency on foreign oil." Crowder recently received the E-Visionary award from the Electric Vehicle Association of the Americas. The organization recognizes leadership in helping to transition the transportation sector to the use of clean and efficient vehicles. Law enforcement agencies are also seeing a lot of positive feedback from the press and general public in regards to having hybrid vehicles. Many police departments are reporting that citizens are asking about the vehicles and how they work. Marion County reports that its department gets a lot of comments at red lights, when the hybrid cars turn off on their own to conserve energy. Unknowing onlookers often "inform" the officer that his car has turned off. Earp tries to educate people about the cars. Earp put in big letters on the side of the car that it is a hybrid and gets 52 miles per gallon. He uses the signs as another way to show the public that he is working for them to save them money. Many news outlets are also running stories about government agencies and hybrid usage, giving many departments free positive publicity. Earp said that he has even been approached by a national television news show about the department's Priuses. He has also appeared in several newspapers because of the cars. Earp doesn't mind being in the spotlight. He just hopes it brings attention to the hybrid technology. He feels that as Americans we should do what we can for the environment and the hybrids are one way of doing that. Environmentally Sound Besides reducing fuel dependency, hybrids also reduce emissions released into the ozone. According to Hybrid cars.com, "a gallon of gasoline weighs just over 6 pounds. When burned, the carbon in it combines with oxygen from the air to produce about 19 pounds of carbon dioxide." The 2003 Civic Hybrid reduces both hydrocarbon and nitrogen oxide emissions by as much as 82%. The 2001-2003 Prius reduces hydrocarbon and nitrous oxide emissions by 97%, carbon monoxide emissions by 76%, and particulate emissions by 90%. The new 2004 models are even better for the environment. Past Priuses are considered Super Ultra Low Emissions Vehicles (SULEV). And last year's Civic is considered an Ultra Low Emissions Vehicle (ULEV). Honda also has a California version of the 2003 Civic Hybrid that meets the even cleaner, more stringent California SULEV standard. The 2004 models for both cars are considered Advanced Technology Partial Zero Emission Vehicles (AT-PZEV)- meaning they virtually give off no emissions. When Size Matters The Honda Civic Hybrid is styled just like the typical Civic. The only difference is the label on the back of the car. The Toyota Prius however, has a completely different styling than any other car on the road. The 2004 model Prius is even larger than past models- comparable to a Camry. The body styling is very similar to the Toyota Matrix in length and because of its hatchback. The cargo room in this model is 30% more than in previous years. Both the Civic Hybrid and the Prius have spacious seating for five. This year's Prius also has a redesigned dash and an electronically controlled throttle and shifting for "responsive performance." The By-Wire technology replaces mechanical connections with more advanced electrical connections. Driver input is transmitted via electronic signals. Toyota said the technology increases Prius' efficiency because of the reduced vehicle weight. The new Prius also has some other interesting amenities like voice-activated DVD navigation with Bluetooth technology for hands-free phone use with compatible cell phones. The car also has the Smart Entry and Start system. While most cars use a key to start the vehicle, the Prius uses a "key transponder" that looks similar to a keyless entry keychain. The car can be purchased with the Smart Entry and Start System or without. With it, there is no need to ever insert a key into the car. As long as the keychain is near the driver- say in his pocket- he can start the car by pressing the on-button. While the cost of hybrid technology is still higher than that of average vehicles, many police departments are finding hybrids to be a perfect fit that saves the department money in the long run. Hybrid Safety Because hybrid vehicles have high voltage batteries, emergency personnel should take precautions when dealing with an accident scene involving a hybrid car. Cut cables and damaged batteries can lead to electrocution and chemical burns for emergency responders. On both hybrid vehicles, the high voltage wires and cables are orange and covered with plastic shielding or orange tape. Never casually handle the orange wiring or the components connected to it. Because hybrids are so quiet, a silent car is no guarantee that a hybrid engine is completely turned off. Always read all warning labels when dealing with hybrid technology. Because some fire extinguishers have metal particles, the safest way to extinguish a fire involving a hybrid is with large amounts of water. If handled properly, hybrids offer no additional risks over a conventional vehicle. Many Toyota and Honda service departments are training local emergency personnel so they will know how to secure an accident scene involving these kinds of vehicles. Police departments should contact their local Toyota and Honda dealerships to see if they offer training. Honda has produced a booklet titled Honda Civic Hybrid Emergency Response Guide. Contact Honda at: (800) 999-1009. The booklet is free to law enforcement. Toyota has produced a booklet titled, Prius Emergency Responder Guide. The item number is: 00422-ERG-020U. The booklets cost $1.25 and can be purchased by calling: (800) 622-2033. 2004 models, Honda Civic Hybrid Toyota PriusCVT transmissionsOverall Value Base Price MSRP $20,650 $19,995 Total Equipped Price $21,140 $20,730 + DPI* Destination Charge $490 $485 ALG Residual Value After 36 Months Not Listed Not Listed ALG Residual Value After 60 Months Not Listed Not Listed Five-year Maintenance & Repair Costs $1,624 $1,487 Ownership Cost Rating Excellent Excellent Fuel Economy (City) 48 52 Fuel Economy (Highway) 47 45 Warranty Basic Time (Months) 36 36 Basic Time (Miles) 36,000 36,000 Powertrain Time (Months) 36 96 Powertrain Time (Miles) 36,000 100,000 PERFORMANCE & ENGINEERING Engine & Transmission Engine VTEC® 1.3L I4 1.5L I4 Electric Hybrid Engine Standard Standard Engine Cylinders Four Four Driveline Front Wheel Drive Front Wheel Drive Engine Displacement 1339 1497 Valve Configuration SOHC DOHC Horsepower @ rpm 85@5700 70@4500 Torque @ rpm 87@3300 82@4200 Standard Transmission Variable Speed Automatic Variable Speed Automatic Fuel System Multi-Port Fuel Injected Multi-Port Fuel Injected Fuel Type Electric Electric Braking & Suspension Steering System Rack and Pinion Rack and Pinion Brake System (Front) Disc Disc Brake System (Rear) Drum Drum ABS Brakes Standard Standard Suspension (Front) Control-Link MacPherson Strut Front Suspension Independent Suspension (Rear) Reactive-Link Double Wishbone Rear Suspension Semi-Independent Stabilizer Bar Standard Standard SAFETY & SECURITY Airbags Standard Standard ABS Brakes Standard Standard Brake System (Front) Disc Disc Brake System (Rear) Drum Drum Intermittent Windshield Wipers Standard Standard Vehicle Anti-Theft Standard Standard NHTSA Front Driver/Front Passenger Crash Test NL/NL 3*/4* COMFORT & CONVENIENCE Interior Automatic Climate Control Standard Standard Air Filtration Standard Standard Power Windows Standard Standard Power Door Locks Standard Standard Intermittent Windshield Wipers Standard Standard Clock Standard Standard Front Bucket Seats Standard Standard Remote Fuel Filler Door Release Standard Standard Keyless Entry/Remote Unlock Standard Standard Tinted Glass Standard Standard Rear Window Defroster Standard Standard Vanity Mirror Standard Standard Map Lights Standard Standard Cargo Area Light Standard Standard Front Accessory Outlet Standard Standard Tachometer Standard Not Available Maintenance Interval Indicator Standard Standard Audio AM/FM Stereo AM/FM Stereo with CD Player and Four Speakers Standard Storage Coin Holder Standard Standard Beverage Holders Not Listed Four Seatback Storage Standard Standard Exterior Power Side Mirrors Standard Standard Folding Side Mirrors Standard Not Listed SPECIFICATIONS Engine & Transmission Engine VTEC® 1.3L I4 1.5L I4 Electric Hybrid Engine Standard Standard Engine Cylinders Four Four Driveline Front Wheel Drive Front Wheel Drive Engine Displacement 1339 1497 Valve Configuration SOHC DOHC Horsepower @ rpm 85@5700 70@4500 Torque @ rpm 87@3300 82@4200 Standard Transmission Variable Speed Automatic Variable Speed Automatic Fuel System Fuel System Multi-Port Fuel Injected Multi-Port Fuel Injected Fuel Type Electric Electric Fuel Economy (City) 48 52 Fuel Economy (Highway) 47 45 Fuel Capacity (gal.) 13.2 11.9 Braking & Suspension Steering System Rack and Pinion Rack and Pinion Brake System (Front) Disc Disc Brake System (Rear) Drum Drum ABS Brakes Standard Standard Suspension (Front) Control-Link MacPherson Strut Front Suspension Independent Suspension (Rear) Reactive-Link Double Wishbone Rear Suspension Semi-Independent Stabilizer Bar Standard Standard Dimensions Curb Weight (Manual, lbs.) Not Applicable Not Applicable Wheelbase (in.) 103.2 100.4 Length (in.) 174.8 169.6 Width (in.) 67.5 66.7 Height (in.) 56.3 57.6 Passenger Volume (cu. ft., mfr.) 91.4 88.6 Cargo Volume (cu. ft., mfr.) 10.1 11.8 Headroom (Front, in.) 39.8 38.8 Legroom (Front, in.) 42.2 41.2 Shoulder Room (Front, in.) 52.6 52.8 Hiproom (Front, in.) 51.2 50.7 Wheels & Tires Alloy Wheels 14-inch Alloy Wheels Standard Tires SBRP185/70SR14, All-Season Tires SBRP175/65R14, All-Season Tires ************************************************** ********** The Boca Raton City Council tonight will approve the purchase of four hybrid cars for the city police department, making Boca a relative latecomer to the energy-conserving trend now sweeping Florida. The council, piggybacking the purchase onto a Florida state contract, is buying the four 2005 Toyota Prius vehicles for $86,060 from Alan Jay Chevrolet in Sebring. The cars will be used to transport assistant chiefs and captains. “We wanted to take a proactive approach to rising fuel costs and lessen the impact on the environment,” Mayor Steven Abrams said Monday. Two of the hybrid cars are new additions to the city’s fleet and two are replacement vehicles for conventional Chevrolets that the city is retiring. Boca Raton is a relative latecomer to the electric car trend, which started when hybrids came on the market in 2001 in 2002. “I think we’re right where we want to be,” said Deputy Mayor Bill Hager. “Government should be at the leading edge, but never at the bleeding edge. Our goal is not to be trendy, but responsible, and it looks like the hybrids are responsible.” Hybrid automobiles save energy and money by running on a combination of gasoline and electricity. The only models currently available are the Chevrolet Silverado, Ford Escape, Toyota Prius and a Honda Civic. The Prius is the most efficient, getting about 60 miles to the gallon when driven in town and 50 miles per gallon on the highway. “I think it’s a great idea, a real positive step forward,” Councilwoman Susan Haynie said. “I know the city of Coconut Creek is very environmentally conscious and has had electric vehicles for awhile.” Chris Wilson, Toyota’s government fleet sales manager for Florida, said the company had sold nearly 300 hybrids – more than half of those in Dade County – in the last three years prior to the Boca deal. “They’re definitely catching on with municipalities and individuals,” Wilson said. “The Toyota Prius has become a status symbol in Hollywood because it’s so environmentally sound.” But the Prius is not fast enough for patrol car duty, Wilson added. “You won’t see hybrids pulling people over on COPS, but you’ll see them being used for serving papers and for port security patrols. It’s not a pursuit vehicle, although it’s definitely used by law enforcement.” |
Re: Toyota Hybrid Police cars (long article)
Every year there's this big convention somewhere around Detroit or something where they compare all the various cars that are candidates for police use. The one overriding trend is that the most favored are large. If you're going to spend some 10 hours a day in a vehicle packed with computers, radios, emergency equipment, shotguns, spike strips, and a crapload of other stuff in addition to the occasional very bad men, you need room. The Prius would never in a million years be suitable. Toyota's only hope of breaking in to that market would be with the Avalon perhaps.
May I have the source of this article so that I may forward it to our Police Chief and City Manager??? We are 'bout ready to purchase 4 new administrative police units and 2 pursuit units and I'd like for them to at least take a look!!!
I've also copied this to our Purchasing Manager.
Our purchasing manager pretty much thinks hybrids are a joke. The Police Chief is receptive but doesn't think it's practical for the department's use....maybe this will change his mind since he knows most of the people in that article. The City Manager is very receptive but has deep concerns about spending the City's taxpayers money on these things. He likes my cars and thinks they are a good idea but I think he is waiting for another city to take the leap first. www.eustis.org |
Original article?http://www.pfmmag.com/JulyAugust2004...policecars.htm
Thank you very much!!!!
Outside of another 45mph chase of O.J. Simpson on an L.A. freeway (which would probably result in some killer mpgs!), I'm trying to imagine how a Prius or a HCH would handle high-speed chase situation. Those Crown Vics have around 400hp under their hoods with beefed up suspensions and transmissions. Hybrids would be great for other city functions, but I think it's a huge stretch for a police car (with the exception of parking violation squads).
Jeff |
A police issue Crown Vic Interceptor has a 250hp V8. Even the upcoming Challenger and Magnum Hemi V8 Interceptors are "only" 340hp, although both the Hemi vehicles will do 145mph compared to the 130mph of the Crown Vic Interceptor. Point still being they might be fine as administrative vehicles, but not persuit or transporting bad guys. I'll see if I can find the article with the breakdown of all the most recently reviewed police use vehicles and repost it here.
I would have to agree, the crown vic is the last of the big cars and is ideal for transporting bad guys.. However most agencies are opting for no pursuit policies as the public wants to sue over loss of property & lives. Plus the rising costs of fuel
Marion County Fl is using the Prius as a fully marked unit, for field service deputies and unmarked for admin & investigators. Alot of other departments are following the same trend using toyotas and honda's. |
Around here we have pretty strict limits on high speed pursuits and the results have been (a) some police not reporting their speed in order to chase without being told to stop, and (b) police using more communications to strategically intercept suspects in a safe and much more effective manner.
It hasn't been an easy transition, especially for the real hotshot cops that loved to chase, but in the end it has proven to be both more effective and of course safer for everyone on (and off) the road. That being said, much of the police force could use hybrids, but it's hard to give up old habits, and large luxury cars are certainly going to be hard for most police forces to give up, although they are... I've seen some smaller GM police cars, I guess they buy them in bulk packages. |
