Electric Vehicle Forums
-   Honda Insight II (https://electricvehicleforums.com/forums/honda-insight-ii-82/)
-   -   CVT "Jerks and Shudders" on engagement (https://electricvehicleforums.com/forums/honda-insight-ii-82/cvt-jerks-shudders-engagement-28563/)
wilgriffin Feb 3, 2013 07:56 AM
2010 Honda Insight LX with 93,000 miles. Lots of long distance commuting!
I understand from Civic articles that this might be caused by the start/stop clutch but I have been unable to find the solution to the problem. I recently drained and replaced the fluid with Honda CVT at $8.99 per quart from my local Honda dealer. I actually did 3 drains and refills per recommendation online.
Jerking improved for awhile but it is back to its old ways again. Worse during cold weather. CVT is full. Is there a fix short of replacing the start/stop clutch?
Are there any additives that might help?
Thanks!
wilgriffin Mar 18, 2013 07:29 AM
Re: CVT "Jerks and Shudders" on engagement
ZMAX HELPS! Althought Z Max transmission fix is not yet approved for the Honda CVT, I decided to try it anyway. I got significant improvement during the first test drive. There is still some jerking when the transmission oil is cold but the shifts when warm are much better. I used 2 bottles: about $20.00 at my local Wal-Mart. I will post any problems I encounter but so far there are none.:)
mpk Jul 11, 2016 09:47 AM
Checking in for an update after a few years. How are the CVT shifts?
philmcneal Oct 25, 2018 08:36 AM
Did you try changing the internal and external filters? Total should be shy of 5 Liters. instead of the drain and fill procedure of 3 liters.
https://www.insightcentral.net/forum...er-change.html
