Why does Engine Restart when put in Park?
When I pull into a parking space or drive into my garage to park, AS kicks in as I would expect. However, when I place the car in Park, the engine restarts. Now when I park, I turn off the ignition and then put the car in Park. 1) is that bad for the transmission? 2) my door locks have to be manually unlocked as a result. Thoughts? Advice?
I'm a 10-day newbie and have spent way too much time on this forum in the last two days! |
Re: Why does Engine Restart when put in Park?
I was wondering why it does it as well.
I know the auto stop Auto. comes back on when you release the break, but I don't think it should if you shift the gears, and the book says it does. Whay I have been doing when I park, is if it does go into auto stop, I turn off the car before I put it into park. Now my question, is what I am doing bad or wrong? |
I always turn the car off before putting it in park too.
Turning the engine on in park makes no sense to me at all. I can't imagine why Honda designed it that way. |
I would follow the Owner's Manual's instructions for parking. Even if we don't understand the reasons why the engine restarts, that doesn't meant that there are none. Although these cars are designed to be idiot-proof, that isn't a license to subvert its mechanisms. Would you and can you park this way with an ordinary car? Perhaps so, but try and explain that to law enforcement or in claiming a warranty if it is the cause for some misfortune.
There is an extensive thread on this very subject.
Try the search feature. Many folks here, including myslef, turn the car off when autostoped in D before putting the car in P. |
See this thread: https://www.greenhybrid.com/discuss/...stopping-1941/
for other reactions to this question. My personal response, and that of many posters here, is that the fact that the engine turns back on as you shift from drive to reverse can be easily and safely circumvented by keying off (just one 'click') while in Drive or Neutral before you shift to Reverse and then Park, and only removing the key after you are in Park. It takes an extra step when you're shutting down the car, but it only takes a second, and it can be done very automatically once you are used to doing it, little thought or effort required. The consensus seems to be that there is no reason to think this would harm the car in any way- the engine is off already, to be sure, and plenty of cars with MT are shut off that way regularly. |
Been said, but in order to get to 'Park', you have to go through 'Reverse', and since that isn't 'Neutral' or 'Drive', the engine starts. My shutdown process, easy on the CVT:
- Pull into parking spot, shift to N (whether AS engages or not) - Pull hand brake - Turn off engine completely - Shift to P - Remove key, go about my life. |
None of these threads address the reason WHY the system turns ON. All these threads just say it's ok to do this or that but I would like to know the reason the system goes back to the ON state. I believe it turns on the second it comes out of DRIVE... not when it goes into REVERSE or PARK. I'm sure the engineers have a reason for this or they just missed this scenario. That's the question... if by design, then why. If missed...then ok... we now know.
I think the reason why the ICE turns on is, the engine does not go into AS when in reverse. When you shift to reverse it starts ICE in preperation for you to reverse. It does not know what you are up to! It would be nice to have AS in reverse, then our problem would not occur. There is no reason why it has to restart in reverse untill you release the brake really, but it does. I can not for the life of me figure out why the ICE has to start in reverse. But there may be a reason. H
| All times are GMT -7. The time now is 08:20 AM. |
