How do you know when the car is "lean-burn" mode? Is there an indicator that shows this?
This is a very good question. Unfortunately, there's no indicator to tell you that you're in lean-burn mode. I wish there was.
I was thinking about this question this weekend while making a drive from Cincinnati to Indianapolis and back. I came to this conclusion (I have the 5-speed): When you're on a flat road, at a constant cruising speed and your FCD shows 60+ mpg, you're in lean burn. If you press the gas lightly, on the 5-speed, if you're already in lean-burn, the car will go down to about 56 mpg on the FCD, then there's a small surge as the car leaves lean-burn to respond to the throttle. The FCD will jump to 40 mpg, and any further pressure on the gas results in assist + lower FCD. Therefore, I've come to the conclusion: if your FCD shows 60+ mpg and the engine is warm, chances are you're in lean-burn. Mark |
