Re: Oil Change Revisited
Originally Posted by inFiniTE LooP
when i purchased my car i also purchased a "car care service plan" from my dealer, which gives me discounts on all of my services (oil changes, tire rotations, transmission fluid changes, etc.) . it all comes in a booklet and tells me at how many miles i should be coming in.
the first ticket in the booklet is for an oil and filter change and says it should be done at 3790 miles. in the booklet it seems they recommend service every 3750 miles (my car had 40 miles on it when i purchased it). i just wanted to follow my service plan booklet, should i wait until 5,000 miles then :confused: ? In the end it is up to you, but I always follow the owner's manual recommendations. ~Droid |
well i just checked out my manual for myself and sure enough what you said is in there, now i'm wondering what i should do :( . that other thread was quite interesting as well concerning when everyone has been changing their oil, i guess i'll bring it up with my dealer and find out just how far over the mileage can deviate between the booklet and my odometer.
The "free" extended warranty (72k miles) of my HCH is voided if I don't change my oil every 3750 miles as well as have other BS done every 7500 miles (which cost around $150 each time) at the dealership. I'm really wondering if this is worth it or not.
~Droid |
I agree that an extended warranty CAN be a good thing but that depends on how you drive. Like if I floor it at green lights or drive crazy in assorted ways, the car will die earlier. I'm no expert so I'm just guessing on that one. All my previous cars, though, lasted a long time and I always sold/donated them before they died.
Originally Posted by clayk
I thought you were supposed to wait until 10,000 as well. My 05 HCH has about 6000 on it now. I checked it the other day and the oil appeared dirtier than I normally let my oil get before I change it.
So now I am wondering if I should go ahead and take it in. Clay |
Originally Posted by Wangofree
I would definitely get in for an oil change. There are probably a few bits of metal floating around in that original factory oil that needs to be flushed out with your first oil change. I wouldn't wait until 10K. I did mine at the 4,000 mile mark.
What lars-ss and droid said is right on target. |
Originally Posted by rigger
We've gone through this discussion several times before. The reason it states to wait for your first oil change is Honda uses a "special break in oil", I'll trust the manufacture before I'd trust the dealer...
What lars-ss and droid said is right on target. Does it really matter when you have your first oil change? In the long run, probably not. Why is that? 1. Most new engines are basically "broken in" right from the factory. 2. The "break in" oil has qualities that help the pistons seat, but after 3,000 miles, you're probably about as "broken in" as you're going to get. If you've varied your speed during this period. 3. Replacing "break in" oil with a high quality 0w20 or 5w20 synthetic oil will start your engine down a long, healthy and happy life. 4. If you do your own oil changes, you are in control, both economically and time management. Oil is the blood of the engine. The filter "purifies" it, and it's up to you to decide when to have the oil changed. To change it too often is just costly. It won't hurt your engine. To wait and change it too late, and you run the risk of engine wear and premature failure. Now, here's the "big point", if I had to rely on the dealer or outside source to change my oil, I would opt for longer mileage ranges. 7,500 miles. But since I change my own fluids, using Mobil 1 0w20, I change the fluids on the "severe" schedule at 5,000 miles. What it comes down to is whatever allows you to sleep at night. :angel: |
Chances are the bodywork or other running gear will be dying well before the engine needs reconditioning, that's if you keep your cars that long - most people trade-in for something else within 3 years, so any anal retentive hair splitting over servicing beyond manufacturer recommendations will be for someone elses benefit - who may not look after your car even half as well as you did...
