Lurching on restart
New owner here.....
Only had my HCHII for a week but have already noticed a possible problem. When starting up from a stop light, the engine is up and running before I can move my foot from the brake pedal to the gas, but the cvt does not engage as smoothly as I would like. It's more of a quick jerking motion rather than a lurch. On several occasions, I thought the guy behind me had bumped me. On those rare occasions where the traffic light turns green just as the auto-stop turns off the engine, it's REALLY noticable then. Is this normal? or do I have a problem? Thanks! |
Re: Lurching on restart
If it's brand new, it's more likely a driver-education problem than a car problem. I experienced the same thing you describe when I first got my car, and eventually realized I was moving my foot from brake to gas faster than the IMA could spin up the crankshaft and re-engage the clutch. Slow the motion down a little, ease up on the gas (yes, 4000rpm is excessive), and see where you end up.
Also, which area of the country are you in? There's a couple of folks on here (myself included) who are willing to sit down in the passenger seat if the person lives close enough. |
Thanks for the info.
I'm in Maryland btw. |
Sounds normal depending on how you're getting onto the throttle. The auto-clutch is really just like a normal clutch in this respect: the "driver" (in this case, the computer) doesn't always get it right, and in those moments you can get a noticeable jerk. On my car, when the weather is cold (20-30 deg. F) and the engine is just started, the clutch engages very abruptly -- if it weren't for the electric assist that keeps the crankshaft turning, the engine would stall.
But all that makes it sound worse than it is, I suspect. Just try different throttle applications (how fast and how far you get into the gas) until you find the feel you want, then drive it that way. cheers -- doug |
| All times are GMT -7. The time now is 12:07 AM. |
