Electric Vehicle Forums
-   Honda Civic Hybrid (https://electricvehicleforums.com/forums/honda-civic-hybrid-12/)
-   -   How fast do tires loose air? (https://electricvehicleforums.com/forums/honda-civic-hybrid-12/how-fast-do-tires-loose-air-6322/)
kenny Mar 9, 2006 05:04 PM
When I fill mine up I go to 40 PSI.
How long will it take for them to fall to 35?
Does it depend on how or how much I drive.
Temp?
yojimbo Mar 9, 2006 08:08 PM
Re: How fast do tires loose air?
It probably varies but mine seems to drop about 1 PSI a week. I usually check mine every 3-4 weeks. I keep them at 40-41 PSI.
Hot_Georgia_2004 Mar 9, 2006 08:41 PM
I check mine weekly and they're usually 1-2lb off. Sometimes no change for weeks.
kettleone Mar 10, 2006 05:08 AM
They should not go down except for changes in temperature.
If you have them all set at the same pressure (using an air gauge), they should all fluctuate in unison. If one is down more than the others, it has a leak somewhere.
gonavy Mar 10, 2006 05:25 AM
There are far too many variables at work to state the answer for your case. All you can do is check them periodically- each fillup.
And find the stations near you that have free air, or keep a supply of quarters. Exxon usually has free air&water
