Electric Vehicle Forums
-   Honda Civic Hybrid (https://electricvehicleforums.com/forums/honda-civic-hybrid-12/)
-   -   HcHII rear ride height (https://electricvehicleforums.com/forums/honda-civic-hybrid-12/hchii-rear-ride-height-21401/)
hchluv Mar 31, 2009 03:15 PM
I have done a search and came up empty.
I was looking at my tires today and noticed that the left rear is at least
3/4" lower then the right rear. Fronts are within 1/8" of each other.
As a test I put my other car in the same spot and all corner are +- of each other.
The tank is full and all items removed from trunk. I had the rear control arms replace about a month ago, could a spring go bad?, or damaged when the arms were install?
Should I be concerned?
Help
Brian :confused:
mmrmnhrm Mar 31, 2009 06:07 PM
Re: HcHII rear ride height
Take it back, the dealership didn't do something right.
bengteck Apr 3, 2009 05:59 AM
sound to me camber problem
can you recall hit any hole or kerb a while back?
could be negtive camber now
take a look at the tire if it wear off more on the inner corner
bengteck Apr 17, 2009 05:53 AM
i've found the cause of your problem
they are manufactured with the "defect" on most civic
i checked mine, same 1/4 diff as yours
but i was informed by the local distrubutor that Honda feedback to them
"not service affecting" so they are doing nothing to correct them
Mendel Leisk Apr 17, 2009 11:57 AM
Wonder if it has anything to with right-hand (Japan, Australia, etc), vs left-hand driver position.
Lansing May 14, 2009 10:04 PM
Help
Brian :confused:
I found the same thing. I eyeballed it one day, then took a tape measure to it and sure enough....1/2 inch difference.
Anyone??
psyshack May 15, 2009 04:39 AM
Help
Brian :confused:
The spring. Take it in. I had to have a spring replaced on my 06 EX Sedan.
bengteck May 26, 2009 05:57 AM
let me repeat myself again
it was Honda defect from factory
i've checked with all other Civics and found all has the same fault
and nothing to do with right or left hand drive since US guys also reported same fault
mine was replaced with after-market coilover but has the same problem
so its nothing to do with spring or damper
it can be easly corrected with my coilover setup but i rather leave it
Harold May 26, 2009 08:35 AM
I just had the camber issue repair and two new springs added. Left side is low! Hal
bengteck May 27, 2009 05:57 AM
mine aftermarket SPC camber and adjustable but believe that do not help
i measured all imaginable part near the wheel arch for reference but fail to find any fault with exterior panels
I’ll inspect further on my next servicing at Honda authorized distributor
