Considering purchasing 05 Civic Hybrid
Hello all,
I came here to ask some advice on a 2005 Civic Hybrid I'm considering purchasing for my girlfriend. We love our Hondas (my 88 Accord and her 01 Civic), but the transmission went out in her Civic, and the repair is more than the car. She's always wanted an 05 Civic Hybrid, and so I've been looking around for one. Found one nearby in Ohio and we went and took a look at it. 05 Civic Hybrid CVT 175k Miles The good: The car started up! (always a plus) Drove straight down the road, no pulling Accelerated to 45mph smoothly (no highway near the dealer) Engine sounds pretty good. Slight lifter tick on cold start. Everything seems to work. Very little rust only on wheel wells. Underneath no rust The bad: I've done some online research on this issue, and this car has the shudder when the IMA starts assisting right about 5 mph. Once past that, it drives great. I didn't have a chance to check the transmission fluid, which I will next time I look at it. From what I understand, often a simple transmission fluid change and burnishing the starter clutch often takes care of the issue. I'm familiar with motorcycle clutches, brake pads, and other such friction materials, and know how sometimes things can get glazed over. Based on the experiences of many people who have posted on this common issue, it seems like something which I will be able to take care of myself, but there is the specter of a new purchase. What is a worse case scenario of this issue? Since we are coming from a transmission issue, I don't want to purchase another problem car. How likely is it that its a catastrophic failure as compared to a simple regular maintenance issue specific to these hybrid CVT transmissions. If a fluid change and a clutch burnish don't solve the issue, what is the long term damage that would be caused by continuing to drive with this issue? Any advice from a more experienced person would be appreciated. Thank you, Twitch |
Re: Considering purchasing 05 Civic Hybrid
Run away from this car. You have CVT judder, and you'll have to drop another $2200 on a new battery soon.
Honda Civic Hybrids are problem cars. Period. |
Is the shudder related to a poorly performing battery? I was under the impression there was a clutch pack that can get glazed over. I have been seeing there are many problems with these cars, I myself have been looking into an insight with a Manual transmission. The problem is my girlfriend seems pretty set on this model year. She is a Honda loyalist, and since her old Civic broke she's set on having her next vehicle be a hybrid. Does the next generation civic hybrid have the issues taken care of, or are these continuing problems across the board. Pretty sure we can talk the salesman down to $1500 with new tires the way it sits.
No. The judder is a problem with the CVT. Sometimes the burnishing process fixes it, but it's usually temporary. The only permanent fix is a start clutch replacement, which will cost more than what you're paying for the car. Note that I wouldn't take the car if I were PAID $1500 to take it... well... yeah. I would. I'd drive it straight to the salvage yard and collect another $500.
Their batteries are just bad. Period. You should count on spending another $2200 for a battery in the near future. Most used hybrid purchasers find themselves replacing the hybrid battery shortly after purchase. The newer generation civic hybrids only get worse until the lithium based 2012 and newer. Those are fine. Please note that I have owned 2X 06 Civic hybrids, and I still own an '02 and '05 Honda Insight. Of the 4 vehicles, there have been 7 battery replacements. I have also worked on many other car's batteries. I do not recommend purchasing used Honda hybrids for people who want inexpensive, reliable and fuel efficient transportation. You won't get all three, and often you'll get zero. With only a few exceptions, Honda hybrids are pretty much the worst hybrids out there. Your money would be better spent on another regular civic. If you're dead set on a Honda Hybrid, the 05-07 Accord Hybrid (battery is still an issue with these) and the 2010+ Insight are reasonably reliable. I don't remember which years, but I think it's the 11 and 12 Insights that had big problems with their piston rings. Do your research and avoid those. |
Thanks for your insight (pun intended). I'll talk to her about changing her mind on the hybrid for her car. As for me, I have always had a soft spot for misfit cars, and also am an electrician/Maintenance technician and the challenge sounds interesting, but maybe for something I'm driving not something she's driving.
Unless you have cars to loan her for when they break down, then no. It's a bad idea for her.
If you enjoy projects and challenges, a manual G1 Insight is a good choice. |
I actually always keep one extra car licensed and insured for when something else breaks down. It's a 78 Chevy van, but she seems to not mind driving it (though parking is a whole other story.
The G1 Insight is what I was looking at. I enjoy two seaters, and it's one of the few cars built after 1990 which I find aesthetically appealing. |
Originally Posted by wheelhorse2347
(Post 264292)
If she loves 2005 Civics buy her a conventional one. Since you mentioned rust you might want to see if you can bring one in from California, Nevada, or Arizona, where cars basically never rust. (Maybe a little bit if the car lived right on the coast, from the salt air.) Although at that price point the transport would be nearly as much as the car. If she must have a hybrid get a Prius instead. I hate the driving experience but they are ultra-reliable and historically quite inexpensive to maintain. Just be aware that in any hybrid the big battery is an expensive disposable item, so you have to budget for that. Buying a used old hybrid is likely to make that purchase a sooner rather than later event. |
Originally Posted by pasadena_commut
(Post 264306)
This so hard. Toyota knocked it out of the park with the Prius. Even the first gen is better than any Honda NiMH hybrid. Period. The Insight was a technological marvel on several fronts, but they should have gone with the prismatic modules instead of the sticks. Based on my sample of about 110 packs, most Prius battery failures occur in the 140-180K range with outliers at both ends (lowest 77K, highest 290K). About 1/4 of the packs I've replaced have been for people that have owned their Prius for less than 6 months. Reaching a little further... hybrids have two propulsion systems with MORE potential failure points - all of which are usually expensive. If the goal is inexpensive, reliable and fuel efficient transportation, a used hybrid is RARELY a good choice. Trust me. I've owned 8. |
(Post 264309)
(Post 264309)
(Post 264309)
