Re: civic 2008 charging issue help
(Post 276739)
What are the 11 votlages?
while checking first start from 12 and increase as like 12-24-39... |
now giving other issue on dash(after make jumper to obd) B2990 51 and after turnon ignition one relay on ima battery cliking 4 times then stop. while clicking that relay on dash have ima light while ignition open position then relay stop and ima clight closing on dash. with diagnostik tool getting fault P0AE1
Originally Posted by hakancpu™
(Post 276749)
do you mean each cells voltage? or should I get the pin 11 first and check others or between B pinouts have to see voltage?
(Post 276751)
The 11 voltages mentioned in post #4 with the linked diagram.
https://cimg6.ibsrv.net/gimg/www.gre...64f3207a53.jpg that pin is empty |
The plug is exactly how it should be. Again, per post #4:
Viewed from BACK of plug, i.e., you probe the connector from the wire side while the connector is plugged in. It may take an uncomfortable amount of force to make contact with the metal crimps on the wires. Sharp voltmeter leads help. Auto-ranging or 20V or more scale on the meter. The diagram in post #4 corresponds to the orientation in the TOP picture. So, plug the thing back in to the computer and probe it per the diagram. 6-14 14-5 5-13 13-4 4-12 12-11 7-1 1-8 8-2 2-9 9-3 |
B6-B14=14,78V
B14-B5=38V B5-B13=12V B13-B4=0V B4-B12=12V B11-B12=12V B7-B1=12V B1-B8=36V B8-B2=12V B2-B9=36V B9-B3=12V so checked out all and looks like that |
I think my fault could not put back the cells in correct line. So do you have any information about that cell place?
You are checking them wrong.
https://cimg6.ibsrv.net/gimg/www.gre...8739bb436f.jpg https://cimg7.ibsrv.net/gimg/www.gre...ceb22740cd.jpg |
thanks for all your help. solved that
What are the 11 values?
