2004 Civic Hybrid Controller ?
Bought the car 1 1/2 months ago and the IMA system seemed fine.
IMA and engine light came on with P1433 and P1433 pnd codes. I reset the codes and 20 min. later they came back. Drove for a while and reset again. so far 3 days later, no codes or lights. Here are my IMA system symptoms:
My questions are :
Any advice would be greatly appreciated! My CVT is also acting up and has the wrong fluid in it. I have an appointment for Diagnostic and the burnish procedure at Honda tomorrow 2-3-15 as well as the airbag recall. |
Re: 2004 Civic Hybrid Controller ?
http://bumblebeebatteries.com/hybrid...y-replacement/
Your battery is going bad. You are describing forced recalibrations. Now would be a good time for a grid charger. Replace your CVT fluid every other oil change with Honda CVT fluid. |
Thanks for the advice!
Originally Posted by Northeast2000
(Post 255568)
If you have a 90 day warranty or return privileges exercise them now. Then buy yourself a good used Corolla or conventional Civic, if you are looking for a cheap reliable car. If, on the other hand, you enjoy dealing with crazy expensive failing car parts, then welcome to the world of the HCH! |
