How do I replace the cabin filter. Where is it?
:confused:
Re: How do I replace the cabin filter. Where is it?
Mitaka
First empty the glovebox.Then on the right side is a lever that keeps the glovebox from flying open,push on the bottom to disengage. After the lever is unhooked reach up and squeeze the sides of the glovebox together and allow it to swing down exposing the cabin filter lid. Undo the catchs and remove the old filter.Replace filter taking care to orient the airflow arrow correctly then reverse the disassembly procedure!:D |
Thanks a lot
Try this for more detailed instructions with pictures - http://www.vtec.net/articles/view-ar...icle_id=355466
Okay, so mine doesn't have pretty pictures... But I've got a link to a good source for filters!
https://www.greenhybrid.com/discuss/...ead.php?t=8066 |
A couple weeks ago, I decided to change the CAF in my Odyssey. It's the original filter. It was installed upside down! It must have been football season on the assembly line (you've gotta have seen those commercials to get that joke).
