10 more HP on premium fuel
According to this article:
http://www.usatoday.com/money/autos/...1-accord_x.htm The Accord V-6 ratings assume regular-grade fuel, and Honda will market it as a regular-fuel engine. But — pssst — it's good for another 10 hp and 10-plus lbs.-ft. on premium, acknowledges V-6 engineer Asaki. I'm just itching to try it and see if it makes any difference, although I know it's not very "green." |
Re: 10 more HP on premium fuel
Your comment that it is not green is right on.....Why is HP important (unless you run at the peak of the HP curve all the time)? Why is torque important unless you are constantly pushing for a better 0-60 elapsed time? Why then does it matter the impact of octane on performance? The real key is what really matters to driveability as you measure it (most of us by MPG). Sorry.....but I obviously do not understand where you are coming from.
On the other hand, if the V-6 engine derates itself by retarding timing to avoid engine knock when using regular unleaded maybe it would be slightly more efficient using premium fuel instead of regular. This may be one of the few instances that premium actually does have a positive effect on fuel economy. |
With the extents engineers will go to get small gains in performance, I'm somewhat surprised that Honda would not advertize the "premium" horsepower ratings, as well as the ability to run on regular gas to save money as an option. 87 octane could still be listed as minimum reccomended, with a comment that 91 could be used for extra performance.
Something does not sound right. High octane fuel is typically used for high compression engines, and is required to prevent pre-detonation. It is actually less combustable (more stable) than lower octane. Does anyone know what the compression ratio is for the Accord v6?
For the HAH, the extra '10' HP and '10' lb ft. would contribute to better fuel effeciency at all speeds. Yes, it would be noticable when you put your right foot into it, but for normal driving it would show up in MPG. |
10.5 to 1 - WOW! Thats surprising. In that case the Accord could definately benefit from higher octane. Are you sure about that Ratio? The LS2 Corvette is only a little higher (10.9:1) and it beats my LS1 Z28 (10:1). If you run either of those cars (Corvette or Camaro) on anything less than 93 your mileage craps out and the performance bogs.
Interesting! |
Interesting! I think I'm going to run a few tanks of premium (the extra cost is only about $3.20 per tank) and see if there's a noticeable difference. |
