Electric Vehicle Forums
-   HCH II-Specific Discussions (https://electricvehicleforums.com/forums/hch-ii-specific-discussions-51/)
-   -   Weired Smell in 2007 HCH (https://electricvehicleforums.com/forums/hch-ii-specific-discussions-51/weired-smell-2007-hch-24642/)
m.isbeer Jun 25, 2010 04:00 AM
Hi all,
I have a 2007 HCH that i just bought, but every now and then while i am driving it, this weired smell, comes out i donno from where, some say maybe from the catalyzer, the smell is like still water that was left for days...
Does anybody have an answer for such a problem
Thanks all.
Mendel Leisk Jun 25, 2010 12:36 PM
Re: Weired Smell in 2007 HCH
Check the cabin filter? It's behind the glove box: you just need to coax the g.b. to swing all the way down, by pushing in it's side walls, to get at the filter.
Dream'R Jun 25, 2010 03:08 PM
Following on from Mendel's suggestion, you may want to see if there is any moisture in the "air box" where the cabin filter is located. When the air conditioner operates, there is condensation formed from the humidity in the air entering the car. There is a drain which leads to the outside under the car but this can become plugged by dirt, mold, etc. (This is why you will sometimes see a small puddle left under the car when you have been using the air conditioning).
Good luck!
Roger
m.isbeer Jun 28, 2010 01:30 AM
the smell only appears when i hit the gaz and the RPM goes above 2.5. is that releveant to the problems you guys described??
Thank you soo much for your help.
Dream'R Jun 28, 2010 09:30 AM
This sounds like it's related to your exhaust system then. The catalytic converter will sometimes produce more odor in the exhaust. The stagnant water smell you describe may also be from condensation in the exhaust which evaporates as the system heats up.
(I notice this when I start my motorcycle after it's been sitting for a while).
I think it would be worth having the entire exhaust system checked for leaks or damage. You should not be able to smell the exhaust when inside the car.
Cheers,
Roger
