P0A27 error.
Hey! My civic have p0a27 error. The hybrid system works but the IMA light is on. Seems the car works fine. What can be wrong, what should i change? The honda dealer in my town never repaired a 2gen hybrid so i know even more about the car than them... They said i need to change the BCM hybrid control module. And it should be changed to the same serial number. Is it true?
Re: P0A27 error.
Most common cause is a poor connection. I assume you eventually replaced the fuse, and since you replaced the sticks, it's highly likely related to a bad connection during reassembly.
Remove and reinstall all connectors in the IPU. |
Re: P0A27 error.
(Post 268279)
Re: P0A27 error.
This is why I hesitate to answer people. The above additional information would have been important to know up front. I had to search your other posts to find out about the fuse, and you never bothered to follow up about the fuse. You hold back information, but you expect to be helped.
The more information you give, the better the results and the less of other's time you waste. I'm out. Good luck. |
Re: P0A27 error.
(Post 268281)
Re: P0A27 error.
Still looking for help :)
Re: P0A27 error.
Still out. Good luck.
