Electric Vehicle Forums
-   HCH II-Specific Discussions (https://electricvehicleforums.com/forums/hch-ii-specific-discussions-51/)
-   -   Major problem in transmission (https://electricvehicleforums.com/forums/hch-ii-specific-discussions-51/major-problem-transmission-24952/)
drabood Aug 25, 2010 01:33 PM
I have HCH 2006 at 56 k mile, suddenly I notice that when I shift the gearbox to D (or S ,L) the car make a loud noise (like a kick sound when u engage the gear incorrectly in manual transmission) and after that when I continue driving I feel that I have to push the throttle more to get the expected speed and I hear also strange sound (like something rub over some metal thing !)
By the way, The car running smoothly when I drive on reverse (R) and I want to mention also that I replaced the CVT fluid at 54 k mile but the CVT fluid wasn't specified for honda it was universal and now when I check the CVT fluid I notice that it's transparent and I couldn't point out the fluid level !
Harold Aug 25, 2010 04:10 PM
Re: Major problem in transmission
I would change it over to Honda CVT oil ASP. I would do the three time change for good measure. Drive between changes to mix the oils together before the next drain and refill. Good luck, H
iridium130m Aug 25, 2010 09:12 PM
For sure get the honda fluid in! I wouldn't risk anything else. when you replace it, the drain plug is also a magnet, i'd be curious how much filings have accumulated on it now vs. your first change (mine only had a very thin layer of metal power, i assume its wear on the belt rubbing on the pulleys since they constantly change their diameters for the various gear ratios.)
As for the kerthunk, mine will do that and be more difficult to pull out of park if I don't set the parking brake BEFORE I put it in park on an incline.
So if you park on an incline, set the parking brake first while still in drive and not moving, then put it in park. The puts the stopping force on the rear brakes and will save wear and tear on the tranny's parking pawls, should hopefully get rid of your kerthuck when pulling it out of park.
stevenvillatoro Aug 25, 2010 10:02 PM
Great tip, thanks!
drabood Aug 27, 2010 08:06 PM
Thanks every body....
I went to the dealer and they said that my ( ROD, TORQUE (LOWER) ) was broken, this part is one of ENGINE MOUNTS parts.
They replaced it by one new and every thing back to normal ;)
Mendel Leisk Aug 28, 2010 07:21 AM
Good to hear! Now ASAP (if you haven't already), I would follow Harold's advice regarding the CVT fluid. The Owners Manual is quite emphatic: only Honda's CVT fluid should be used.
