help 2008 honda civic hybrid red 12v battery and ima
Hello there. I live in Turkey. mechanics don't understand hybrid. I replaced my high voltage batteries in my civic with batteries from china. now i am getting the p1570 error. 12v battery not charging. ima battery is also not charging. please help me.
Re: help 2008 honda civic hybrid red 12v battery and ima
Originally Posted by concunus
(Post 275456)
Charge 12V. Many errors are weak 12V.
P1570 = 11 battery module voltages too different. Bad build or bad sticks. Many Chinese sticks are bad. |
When I measure the batteries one by one they are over 16. Should I try with the new 12v? Thank you very much for your quick reply.
(Post 275463)
Hello S Keith. I did what you said. I leave the measurement values and the picture of the place I measured in the comments. I look forward to hearing from you :)
https://cimg9.ibsrv.net/gimg/www.gre...a4da00b4c.jpeg https://cimg0.ibsrv.net/gimg/www.gre...989ddcb6f.jpeg |
You need to take measurements with the plug installed.
My problem is solved. I screwed the batteries wrong. I fixed 4 null values. all outputs are the same now. thanks man you are a king. Greetings from Turkey. :)))))
Glad to hear it!
| All times are GMT -7. The time now is 03:04 AM. |
