Re: Glide vs. Assist vs. Charge
Originally Posted by kenny
(Post 137296)
I don't glide.
I don't know what it is. |
61.4 MPG w/o gliding, eh? YOU ARE A GOD
Originally Posted by mechanicjesus
(Post 137287)
So I guess that the theory is if you don't let any more air in then you have nothing to compress. Interesting have you ever tried to turn an engine over by hand with all the valves closed still seems to make compression. Now all you have done is make me want to go tear my brand new engine apart to see exactly how it works. I think maybe I should put a few more miles on first thou. Thanks for the video it was quite interesting.
This engine has a good high compression ratio, too, so there definitely has to be *some* kind of equalizing happening or the engine would always be pure drag, and it's clearly not when the fuel is shut off and valves are closed. cheers -- doug |
Originally Posted by Mr. Kite
(Post 137303)
If you don't know what it is, how do you know you don't do it?
Why bother with all of that complicated stuff? |
Originally Posted by gumby
(Post 137445)
So, you're the one that voted (twice, I see) for "brand of deoderant."
Uhm, no I voted one for it. |
(Post 137927)
My point is I don't hassle with any of that big long list of fancy techniques and still have a lifetime average of 64.1 MPG over 31 tanks.
Why bother with all of that complicated stuff? Yes. You've got it made. You are able to have your trained monkey set the cruise and drive you in to work while you nap. You arrive to work very refreshed and with a very high mpg. And to top it off, you get to brag about how skilled you are as a hypermiler. Hey, you've got the numbers to back it up. Kenny, you are living the high life. Now why would anybody mess around with the "complicated" stuff? https://www.greenhybrid.com/discuss/...ad.php?t=14705 What do you think you could get driving under my conditions Kenny? |
John, I never said all the stuff doesn't work.
I have even said maybe I could to better with it. But you are right, mild climate and a flat commute help a lot. So is being willing to break out into a sweat at 93 degrees and take my shirt off instead of turning the AC on or opening the windows. Living in LA is not everything. I make sacrifices too. I just don't do all the complicated brain stuff. YMMV. ;) |
(Post 137940)
(Post 137940)
(Post 137940)
I make sacrifices too. I just don't do all the complicated brain stuff. |
I am looking forward to hearing how to glide - maybe I will try it or maybe I am already doing it....
is it: - putting trans in N with ICE on? - balancing regen/assist to ~zero net - with FE pegged at 100+? - trying to get a few bars of assist - with FE pegged at 100+? - something else? I have a mainly flat commute and wont go much less than 55-60 (speed limits 55,65) and will use CC. I get about 64mpg on this commute but may use things like gliding if they really help much. I suppose if I reduced my max speed to 48 or 30-40 the I might push 70mpg, but for me thats too slow. |
It's your pegged FE, no charge/no assist state, Spartybrutus, and one way of getting there is feathering the throttle -- if you lift out to regen, and then ever-so-slightly press back down to eliminate regen but not hit assist, while keeping the iMPG pegged at 100, that's the sweet spot: no regen drag, no discharge, 100mpg+ FE.
cheers -- doug |
