dealer cost for installing a block heater?
hello all,
after much delay, I'm following all the good advice on this forum and having an engine block heater installed on my 2008 HCHII. However, I live out in sunny Portland OR, and my local dealer doesn't have much of a clue about doing the installation--- not encouraging! They are also quoting an install cost of $280.00, which seems ridiculous, but I haven't found any recent comparisons from other folks who have had a block heater installed in the U.S. Anyone have a recent experience with a dealer installation they can share? How much they charged? thanks PCope |
Re: dealer cost for installing a block heater?
I don't have any hard numbers to back this up, but $280 sounds reasonable. In addition to the block heater itself, you have:
- Labor (drain coolant, install heater, fill coolant) - Coolant (the actual fluid) - Disposal of old fluid |
I got mine installed here in MN for $70. That is for labor only, I bought the part at hondapartsdeals.com
If you had it installed at our Dealership, it would be 189.00 plus tax for parts and installation...and im in san Antonio TX where we NEVER need these and our guys know how to install them just fine....its actually pretty easy.
The part also comes with specifics on install....just saw them myself. CBond (PS - the Heater is a Plug-In type thing....and you dont have to drain the coolant and all just to install it) I have the instructions for anyone that may need them by the way. |
I live down in Salem (thats 30 mins south for you non-Oregonians), and am wondering what you hope to accomplish by having a block heater? We don't get that cold that often - unless I misunderstand the purpose of the heater...?
thanks, all, for the responses; I also called around in the meantime and got a quote from another area Honda dealer for $150 ($254 with the part, but I already have it). I've done a lot of work on my other (older) cars, but I'm feeling whimpish about digging into the HCHII just yet.
In response to limey6413's question, I've been struggling with sub-optimal conditions for 'hypermiling'-- unavoidable hills, lights, relatively short commute, carpoolers, our 10% ETOH gas. Postively demoralizing! One clear difference on my daily trip to work is whether the car is warmed up or not-- at least 10 mpg difference over the first 5 miles, which is about the length of my commute. So even though the Willamette Valley (Portland, Salem, etc) doesn't get that cold, the engine temp clearly makes a big difference. After reading the other posts about the value of engine block heaters, even in warmer climates (like our California neighbors to the south), I thought I'd give it a try. cheers PCope |
Originally Posted by pcope
(Post 177948)
In response to limey6413's question, I've been struggling with sub-optimal conditions for 'hypermiling'-- unavoidable hills, lights, relatively short commute, carpoolers, our 10% ETOH gas. Postively demoralizing! One clear difference on my daily trip to work is whether the car is warmed up or not-- at least 10 mpg difference over the first 5 miles, which is about the length of my commute. So even though the Willamette Valley (Portland, Salem, etc) doesn't get that cold, the engine temp clearly makes a big difference. After reading the other posts about the value of engine block heaters, even in warmer climates (like our California neighbors to the south), I thought I'd give it a try. cheers PCope WOW Your parts and install prices are crazy where you are.... Maybe its just the market there...but 189.00 was for parts AND Installation here. |
Originally Posted by limey6413
(Post 177942)
It is unlikely that you would ever recoup the cost of an engine block heater on gas savings (especially when you factor in the electricity, albeit a small amount). However, it will help overcome the "pain" of seeing that winter decrease! I have one in the MMH and decided that it wouldn't be worth it to have one installed in the HCH. However, if I could install one myself, it might be worth it. CBondHonda: how easy is it on a scale of 1-10 with 1 being an oil change and 10 being an engine replacement? |
I see - I was worried about my 5-mile commute too, but I'll just live with the pain of seeing the mpg be lower..
My dealer sells the EBH outright for $60, and charges $70 an hour for the install. I couldn't get them to pin down the cost anymore than that.
Originally Posted by CBondHonda
(Post 177938)
