Electric Vehicle Forums
-   HCH II-Specific Discussions (https://electricvehicleforums.com/forums/hch-ii-specific-discussions-51/)
-   -   "Brake System" light on (https://electricvehicleforums.com/forums/hch-ii-specific-discussions-51/brake-system-light-31667/)
Bigfoot100 Aug 23, 2018 09:19 AM
Our 2006 HCH has the Brake System light lit up on the dash. I've checked the basics (brake fluid level), and don't see anything wrong. Braking power is just fine, and in fact the car just passed the state safety inspection with this light on.
One other thing to note: The auto-stop is not working. This seems related. My current guess is that there is some problem with the regenerative breaking system, and with that the auto-stop does not work.
Any tips on how to troubleshoot and/or repair this problem? I took the car to the dealer and was told that they wanted to replace the master cylinder control module for ~$2500. I'm really hoping to narrow this down to something far cheaper...
Thanks for any advice you can offer.
S Keith Aug 23, 2018 05:46 PM
Re: "Brake System" light on
Go to O'Reilly and check the codes.
pasadena_commut Aug 24, 2018 01:11 PM
Really? Seems like "there is a problem with the brakes" is pretty much synonymous with "safety issue".
Did the Dealer tell you why they wanted to replace the "master cylinder control module"? One would hope that they read the codes to come to that conclusion.
Bigfoot100 Aug 24, 2018 06:02 PM
There are no fault codes. I double checked again today, and no codes. Just the Brake System light, and no other symptoms.
S Keith Aug 24, 2018 07:39 PM
Did you go to O'Reilly?
Bigfoot100 Aug 24, 2018 07:43 PM
No, I used the Torque Pro app with a WiFi OBD-II reader.
S Keith Aug 24, 2018 08:15 PM
I suggested O'Reilly for a reason. Lots of codes that can't be read with cheap consumer stuff. The Bosch code readers O'Reilly uses are nearly as capable as the Bosch professional grade units.
Bigfoot100 Aug 24, 2018 08:30 PM
Ok, thanks. We don't have O`Reilly around here, but I'll try Advance Auto or Auto Zone.
S Keith Aug 24, 2018 09:01 PM
I have never been happy with Auto Zone's diagnostics. I can't recommend them at all.
pasadena_commut Aug 25, 2018 05:03 PM
Get the blink codes. My HCHI has an intermittent abs sensor error on one wheel that shows up that way but not with my OBDII code reader.
