Brake & abs light on
ABS & Brake System Amber Light Intermittent & now Constantly on.
Here's what happened : Yellow brake light went on & ABS, checked the fluid level @ reservoir & was low so I topped if off w Dot 3 fluid. Light went off Began to come on off & on ( ABS & Brake light ) Now is constiantly most on . No changes in brake performance . No visual leaks . I cannot seem to find the brake fluid level sensor for sale anywhere. I suspect the sensor is bad. No Codes --> Torque Pro Bluetooth reader IDEAS HELP COMMENTS ?... Please help https://cimg2.ibsrv.net/gimg/www.gre...c4e2060041.jpg Upon starting car ABS come on first https://cimg3.ibsrv.net/gimg/www.gre...c2f7cfaec9.jpg Then Brake system light |
Re: Brake & abs light on
Hi ,
I was able to go to Orielly get their OBD2 reader Front right wheel speed sensor replaced sensor WALA Back to normal . |
