Electric Vehicle Forums
-   HCH II-Specific Discussions (https://electricvehicleforums.com/forums/hch-ii-specific-discussions-51/)
-   -   Battery Indicator going down when parked (https://electricvehicleforums.com/forums/hch-ii-specific-discussions-51/battery-indicator-going-down-when-parked-17841/)
lexasgs400 Apr 21, 2008 05:26 PM
I bought my 2006 HCH with 64000 miles on it about a month ago and love the economy so far averaging 48 mpg through the first 1500 miles. Twice in the last week I went into a store once for about 10 mins and the other for about an hour when I came out my battery indicator read one bar. Does anyone have any ideas? A drain? Bad battery? Normal?
msantos Apr 21, 2008 07:05 PM
Re: Battery Indicator going down when parked
Jason, welcome to GreenHybrid !!!
Don't worry about that phenomenon... unless it happens frequently. The system will,once in a while cause that "depletion" and then attempt a charge to re-set the upper SoC limit.
As I said, if this begins to happen frequently (as in more than once a day or so) and you can clearly see that the SoC has trouble staying at or above 5 bars, then I would take it in to the dealer for a quick check-up.
Cheers;
MSantos
rysa4 Apr 21, 2008 11:30 PM
What does SoC stand for?
msantos Apr 22, 2008 04:53 AM
SoC stands for State of Charge and is represented by the battery charge level display on the HCH-II.
MSantos
