Re: Another DIY: Honda Homelink
(Post 213826)
I'm not sure what color of bezel is used with a grey headliner, so here are both parts numbers.
Interior light base 34404-SNA-A31ZB BASE *YR327L* TAUPE/IVORY 34404-SNA-A31ZD BASE *NH556L*BLUE Lenses 34401-SDA-A21 LENS, R. 34402-SDA-A21 LENS, L. In addition here is a mail order parts dealer that might ship to Canada. Hondapartsdeals Mike |
(Post 213805)
Yes the base is a different P/N for Navi and non-navi interior lights. A Navi interior light base is $24 and the lenses are $5 for the pair. All you need to add is a homelink module like this one for a $100. Once you have the parts, just follow my install DIY, and you are Golden.
Originally Posted by medicmike
(Post 213887)
I wonder if the entire assembly, sunglass holder included, will fit in the headliner with some additional cutting to enlarge the opening. Is the pace above the head liner bump deep enough?
Looking at the install instructions for the OEM accessory Hands Free Link, the directions for cutting out the headliner seem to suggest that it might.
http://www.bernardiparts.com/Images/...k_AII41336.pdf |
(Post 214140)
Gary (initial author of this thread):
I'm about to get my hands on a used Odyssey homelink unit like your initial post. Since my car never had the navigation (and thus no need for the microphone issues) can I assume that the homelink unit only needs 12V and a ground (i.e. just 2 wires) to make it function? I'd like to be able to bench test the unit I am looking at buying, on my work-shop 12 volt battery, to prove it works. Silly question time: what is the procedure for "linking" the unit to my garage doors? I know it involves the "learn" button on my garage door openers, but I cannot remember what else is involved in programming the homelink unit. Much thanks Mike |
Whoops....the O/H unit I was looking at is gone!!!! :(
Originally Posted by navguy12
(Post 214800)
I'm about to get my hands on a used Odyssey homelink unit like your initial post. Since my car never had the navigation (and thus no need for the microphone issues) can I assume that the homelink unit only needs 12V and a ground (i.e. just 2 wires) to make it function? Silly question time: what is the procedure for "linking" the unit to my garage doors? I know it involves the "learn" button on my garage door openers, but I cannot remember what else is involved in programming the homelink unit. Hope this helps. |
3 Attachment(s)
Hope this helps. I am also going to add an "upgrade" to your upgrade. I'd like the map lights to also light up and "theater light dim" in concert with the dome lamp. Note the 3 attached photos...Attachment 1315Attachment 1316Attachment 1317 As detailed in the last picture, I'm going to tap the map lights "off position" into the ceiling light "pink" ground wire.... Cheers Mike |
(Post 214820)
Very much so. Will be purchasing the correct navi-base and lenses for same once I have a homelink module in my possession (or 15 Jan 2010 when I'm in Detroit for the NAIAS, whichever comes first).
