SRS Light - Easy Fix after diagnosis - DTC Codes
I had the SRS light come on a few weeks ago. I found a video on Youtube showing how to reset the light and it stayed off for a little while. Several weeks ago it came back on, would not reset. I searched Youtube again for how to pull the Diagnostic code and found this great video (
It's amazing that we are able to do with just a paper clip! I can only imagine how much the dealer would have charged to do this. DTC, Detection Item 1-1 Open in driver's airbag inflator 1-2 Increased resistance in driver's airbag inflator 1-3 Short to another wire or decreased resistance in driver's airbag inflator 1-4 Short to power in driver's airbag inflator 1-5 Short to ground in driver's airbag inflator 2-1 Open in front passenger's airbag inflator 2-2 Increased resistance in front passenger's airbag inflator 2-3 Short to another wire or decreased resistance in front passenger's airbag inflator 2-4 Short to power in front passenger's airbag inflator 2-5 Short to ground in front passenger's airbag inflator 3-1 Open in left side seat belt tensioner 3-2 Increased resistance in left side seat belt tensioner 3-3 Short to another wire or decreased resistance in left side seat belt tensioner 3-4 Short to power in left side seat belt tensioner 3-5 Short to ground in left side seat belt tensioner 4-1 Open in right side seat belt tensioner 4-2 Increased resistance in right side seat belt tensioner 4-3 Short to another wire or decreased resistance in left side seat belt tensioner 4-4 Short to power in left side seat belt tensioner 4-5 Short to ground in left side seat belt tensioner 5-1, 5-2, 5-3 (NEC), 5-4, 5-5 (NEC) Internal failure of SRS unit 6-1 (NEC), 6-2 (NEC), 6-3 (NEC), 6-4 Internal failure of SRS unit 7-1, 7-2, 7-3 Internal failure of SRS unit 8-1, 8-2, 8-3, 8-4, 8-5, 8-6 Internal failure of SRS unit NOTE: Before troubleshooting DTCs 5-1 through 8-6, check battery/system voltage. If voltage is low, repair the charging system before troubleshooting the SRS system. 9-1 Internal failure of the SRS unit. If intermittent, could mean internal failure of the unit or a faulty indicator light circuit. Refer to Troubleshooting Intermittent Failures (see page 23-38). 9-2 Internal failure of the SRS unit. If intermittent, could mean internal failure of the power supply (VB line). Refer to Troubleshooting Intermittent Failures 9-6 Faulty left front sensor 9-7 Faulty right front sensor 10-1 Seat belt tensioners (and airbag(s)) deployed |
Re: SRS Light - Easy Fix after diagnosis - DTC Codes
Thanks for posting thing. I have had a SRS light my dash for quite some time now with code 3-1. I just have to reset it every couple of months. This video just reminded me to do it. The light should be doing it, but I was so used to it being there now.
Originally Posted by poscivic
(Post 247624)
