Re: Spark Plugs?
Yep, pretty straight-forward task. I gapped and installed all 8 in probably 10-15 minutes.
I found it easier to remove the coil 'plug' before removing the coil/cap itself. |
Re: Spark Plugs?
I still can't seem to "find " my plugs. Are they under the black caps with the two screws on top? I thought that was the fuel injection. I can take off the two "covers" that you mention but still can't locate the plugs. I feel like a real Da, as I have changed the plugs on my cars for the past 30 years myself. Can anyone post a pic on this?
Thanks for your help. |
Re: Spark Plugs?
Under the plastic covers there are eight rectangular things with shiny black tops (at least mine are shiny), four in the front of the engine and four in the back. Each is held on with one bolt and connected to some wires with a plastic connecter that has a thumb clip.
Hay, I found a diagram and downloaded it in the Share ares (here: https://www.greenhybrid.com/share/image1885.html ) . . . the things labeled 1 & 2 are the coils, remove them and you will find the plugs, way down in there. |
Re: Spark Plugs?
Thanks Kernk, that clears it up. I was on the right track. I just wasn't sure if those were the plugs or thefuel injection.
Re: Spark Plugs?
I swapped out the iridium Densos at 108k miles (looked like they had another 20+k miles to go on them really), with Platinum tipped Densos to save money ($2.99 each). Don't bother replacing these plugs unless you notice a misfire.
You will need a 5/8ths in spark plug socket, with a rubber gripper inside, and a 10mm socket, for everything else. |
