ScanGauge XGuage specialty guages for first gen Civic Hybrids
I am pretty sure this is out there somewhere but I am not using the right key words in the search to trigger a meaningful response.
I have a ScanGauge and would like to know what the most useful "gauges" for hypermiling. I know there are some "hidden" gauges. How do I get them and again which ones might be best for keeping track of the IMA battery pack. |
Re: ScanGauge XGuage specialty guages for first gen Civic Hybrids
Unfortunately that info is not in the public domain.
However I build a gauge specifically for the Insight G1 and HCH1 Hybrids which displays IMA data and allows control over the car Soc ;) Currently the HCH1 version displays 8 parameters. IMA Bat Volts IMA Bat Temp IMA Bat Amps IMA Bat Soc Eng Temp Air Temp Fuel Inj Ms Afr Ratio http://www.insightcentral.net/forums...ic-hybrid.html Several US HCH1 owners use it ;) |
So you have a gauge for sale that shows the eight parameters?
Yes visit the link I posted for some details and discussions.
I also have a manual IMA control system for the HCH1 Civic and a fan controller board for a grid charger system. :shade: All discussed and detailed over at Insight central in various threads. OBDIIC&C G1 & HCH1 OBDII Display Command and Control Device for G1 Insight & HCH1 Civic. I have built and tested units, minus the case etc $249 I have kits inc, programmed pic, cable, plug, lcd, components etc (Everything minus the case). $149 I have a plentiful stock of plain pcb's. $49 http://www.insightcentral.net/forums...tml#post202455 IMAC&C HCH1 Ima Manual Command and Control Device for HCH1 Civic. I have built and tested units, inc cable, case etc $249 I have kits inc, programmed pic, cable, components, case etc $149 I have a plentiful stock of plain pcb's. $49 http://www.insightcentral.net/forums...tml#post221868 Current Hack G1 & HCH1 Ima Current Increase Board for G1 Insight and HCH1 Civic. I have built and tested switchable +30% & +44% units, inc cable, etc $199 I have switchable +30% & +44% unit kits inc, cable, components, etc $149 I have built and tested fixed +30% units, inc cable, etc $99 I have fixed +30% unit kits inc, cable, components, etc $49 I have a plentiful stock of plain pcb's. $24 http://www.insightcentral.net/forums...tml#post155028 Fan Control HCH1 Ima Fan Control Board for HCH1 Civic. I have built and tested units, inc cable, etc $149 I have kits inc, programmed pic, cable, components, etc $99 I have a plentiful stock of plain pcb's. $24 http://www.insightcentral.net/forums...tml#post251360 Fill your boots after reading all the info on IC. |
This is going to take a bit of time to investigate.
Any pictures of installation? |
You have to do the work it's all on IC. ;)
| All times are GMT -7. The time now is 12:19 AM. |
