IMA light on, what to do (help)
Less than a month ago I purchased a 2004 Honda Civic hybrid with 77,000 miles on it. Two weeks later the IMA light on my dash came on so I had a Honda dealership run a diagnostic test on it and they said that the IMA needed to be replaced. I am currently in college and don’t have the money to replace the IMA and if I did it would be more than I bought the car for... and suggestions what I should do? I have heard about refurbished IMAs and I have also been reading about somehow disconnecting the IMA entirely so the car will run on gas? |
Re: IMA light on, what to do (help)
I'm sorry you got suckered into thinking this was a good purchase. Used hybrids are rarely a better option than a small four-banger.
Possibilities: 1) The seller likely knew the battery was marginal and didn't disclose 2) Low mileage hybrids aren't great. The fact that the car sat a lot is actually hard on the batteries too. 3) Odometer was a lie. It actually has much higher mileage and a hacked-together battery that wouldn't last any longer than was necessary to get it sold. Drive the car to the nearest O'Reilly Auto Parts (No, not Autozone or anybody else, O'REILLY ONLY!). Have them read the CODES (a 5 digit alpha-numeric code). MAKE SURE YOU GET THE CODES. DON'T LET THEM INTERPRET OR GIVE YOU THE DESCRIPTION. GET. THE. CODES. Your location and the car's history would be helpful as well. |
Originally Posted by nprattholt
(Post 265660)
Less than a month ago I purchased a 2004 Honda Civic hybrid with 77,000 miles on it. The previous post asked where you are in part because if you are in a state which requires smog tests you are in more trouble than otherwise. If the IMA light is on it also lights the CEL, and a car will not pass smog (at least in California) like that. Bypassing the IMA is probably considered an illegal emissions modification in that state too. You care because if it cannot pass the smog test it cannot be (re)registered, and then you cannot legally drive it. If the IMA battery isn't too far gone you can keep it limping along for a while, maybe a year or so, by periodic grid charging. The equipment to do so isn't that expensive, but you have to know what you are doing, have a place where you can do it, and have time for it. If you go this route be sure to change the CVT fluid frequently, lest the equally expensive transmission go out. Economically the most logical thing you could do would be to sell the car, even at a loss, and buy a conventional economy car. A reliable IMA replacement battery will cost you around $3K if you do all the work yourself. If (when) the CVT goes that would be another $3-4K. Spending that is nuts when you can buy a conventional 2004 Civic for around $2K. Yes things will break there too, but they will usually cost less to fix. Even if the transmission goes it will be something that many shops can work on - nobody fixes CVTs, and all the replacements are refurbs of unknown quality. |
Old post but what the heck...... 05 civic Hybrid......When my IMA failed about 2 years ago.... I contacted Honda corporate in Torrance Ca.....the refurbished IMA was $3100 at the time thru the dealer..corporate reimbursed me $2500.....only cost u a phone call...good luck PS...my car was a gift ....personally I dont care for the technology....when/if the car craps out I will get a gas burner... |
