Electric Vehicle Forums
-   HCH I-Specific Discussions (https://electricvehicleforums.com/forums/hch-i-specific-discussions-50/)
-   -   HCH CVT to 6 speed swap? (https://electricvehicleforums.com/forums/hch-i-specific-discussions-50/hch-cvt-6-speed-swap-28521/)
raylit20 Jan 19, 2013 09:20 AM
HCH CVT to 5 speed swap?
Hi guys, I have been doing some searching around and I came across very little info regarding the CVT to manual transmission swap. Would anyone happen to know if this swap has been done before?
raylit20 May 8, 2013 06:34 PM
Re: HCH CVT to 6 speed swap?
I edited the title to correct the typo I made earlier.
This is a bit of an old thread, but the question still remains; has anyone done a CVT to 5 speed swap? If so, is there any information regarding such a conversion?
My current concern is a failing start clutch in my 05 HCH. If It's feasible to swap in a 5mt from another HCH instead of having this trans rebuilt I will go that route.
wyldemannn Feb 19, 2014 06:58 PM
I'm very interested in this as well. I'm guess the HCH flywheel will be pricey, as I'm assuming that's the rotor part of the equation. My wife would much rather have a 5speed in hers so I've started doing homework on it.
privatejoker Jul 7, 2014 03:59 PM
From what I can tell online, the 5 speed from the plain Jane civic is the same as our hybrid's 5 speed. If you're asking about swapping in an Si spec unit, good luck, those will be pricey if you can even swap them.
sonfobert Apr 8, 2017 08:32 PM
Hi! I was wondering If you ever did the swap?
Thanks,
Andrew
