Electric Vehicle Forums
-   HCH I-Specific Discussions (https://electricvehicleforums.com/forums/hch-i-specific-discussions-50/)
-   -   Does anyone have the schedule? (https://electricvehicleforums.com/forums/hch-i-specific-discussions-50/does-anyone-have-schedule-10298/)
Hot_Georgia_2004 Oct 3, 2006 05:41 PM
Does anyone have the maintenance schedule up to 100,000 miles?
You know, the things which need to be checked/serviced and at what mileage.
Thanks in advance.
IMAhybrid Oct 3, 2006 07:22 PM
Re: Does anyone have the schedule?
From OwnerLink, for ~10k/year:
Every 10k
Oil change and rotate tires
Every 30k
Replace air cleaner element
Change CVT fluid (that wasn't on there but I know that's what it is... by the way, I can't believe Sparky is a CVT, very impressive.)
Every 3 years
Replace brake fluid
Check oil and coolant at each fuel stop
Check tire inflation and condition once a month
for more extreme: (every 10k?)
Replace engine oil filter
Check front and rear brake wear
Check parking brake adjustment
Inspect tie rod ends, steering gear box, and boots
Inspect suspension components
Inspect driveshaft boots
Inspect brake hoses and lines (including ABS)
Inspect all fluid levels and condition of fluids
Inspect exhaust system
Inspect fuel lines and connections
Inspect lights and controls/vehicle underbody
I know this probably isn't exactly what you're looking for... you're looking for the list of things that come with that $$$ XXXk service right? Unless just inspecting things costs that much... Nevermind this probably is the right thing. :confused:
realist Oct 3, 2006 09:31 PM
I remember reading somewhere (maybe in the car 'manual'?) that you should follow one of two different schedules depending on how rough you treat the car. I don't have that book in hand at the moment though. However, I do have...
From the service history booklet:
10,000 miles or 1 year:
Replace engine oil.
Rotate Tires (independent of time).
Reset Maintenance Required Indicator.
20,000 miles or 2 years:
Replace engine oil.
Rotate tires (independent of time).
Replace engine oil filter.
Check front and rear brake wear.
Check parking brake adjustment.
Check tie rod ends, steering gear box, and boots.
Check suspension componenets.
Check driveshaft boots.
Check brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
Check exhaust system.
Check fuel lines and connections.
30,000 miles or 2 years:
Replace engine oil.
Check drive belt.
Raplce dust and pollen filter.
Replace air cleaner element (independent of time).
40,000 miles or 2 years:
Replace engine oil.
Check suspension components.
50,000 miles or 3 years:
Replace engine oil.
3 years:
Replace brake fluid, independent of mileage.
60,000 miles or 3 years:
Replace engine oil.
Check drive belt.
Replace dust and pollen filter.
Replace CVT fluid.
70,000 miles or 4 years:
Replace engine oil.
80,000 miles or 4 years:
Replace engine oil.
90,000 miles or 5 years:
Replace engine oil.
Check drive belt.
Replace CVT fluid.
100,000 miles or 5 years:
Replace engine oil.
Check drive shaft boots.
6 years:
Estoril73 Mar 23, 2008 05:44 PM
The schedule mentions of checking coolant at each and every fuel stop, but really who does that?:D
Does anyone know the scheduled interval for flush/replace coolant? Every 60k? 120k?
