A/C problem with Hybrid
Hi,
The IMA light and check battery engine light is on, and my A/C will blow cool air for the first 10 mins and blow hot air after that. Is this related to the IMA battery? What can be the issue? I also found out, Honda actually issued a letter in 2010 to dealers: Before you sell you have to fix the IMA otherwise you will be held responsible for all damages. I bought the car in march 2012, I received that letter also as a Honda owner but I haven't taken it to the dealership to update my codes but would i be able to hold my dealership responsible? |
Re: A/C problem with Hybrid
Get the error codes read to narrow the problem down.
The AC issue could be due to a bad or disconnected temperature sensor. It sounds like you have a newer generation HCH, but here is a thread where someone had an AC issue with their Insight, and if turned out to be the sensor: https://www.greenhybrid.com/discuss/...working-24800/ |
I have a 2004 Honda Civic hybrid.
| All times are GMT -7. The time now is 01:29 AM. |
