Thermostat replacement - operating temperature
How long does it take for your tahoe/yukon to get to operating temperature? it's take mine close to 30+ minutes, which i think is way too long, regardless of it being the dead of winter. My other vehicles are at operating temperature in under 10 minutes.
i have to do a coolant change anyway. So while i'm in there i might swap the thermostat. But, i don't want to swap a perfectly working part if it's not necessary. I know it's "preventative", but it's nothing i can't handle later. So it can wait if possible. |
Originally Posted by IslandCre8tion
(Post 255779)
How long does it take for your tahoe/yukon to get to operating temperature? it's take mine close to 15-20 minutes, which i think is way too long, regardless of it being the dead of winter. i have to do a coolant change anyway. So while i'm in there i might swap the thermostat. But, i don't want to swap a perfectly working part if it's not necessary. I know it's "preventative", but it's nothing i can't handle later. So it can wait if possible.
Re: Thermostat replacement - operating temperature
I replaced the thermostat when i did the coolant change and i got the same results... So i guess in the winter it takes close to 30+ minutes for our engines to reach operating temperature. And even then it may take much longer depending on it switching back and forth to Hybrid mode
They will go into V4 at medium engine coolant temperatures. With a SUV front and rear heater ON the engine waste heat just about keeps up with the cabin heaters cooling the water.
