Sputtering!!!
Hello
i own a 2008 tohoe hybrid. today while my wife was driving the truck lost power. it would not excellerate above 20-30mph. the check engine light went on, and a message scrolled across the dash saying reduced engine power , or something to that effect. the engine was sputtering and jumping all over the [place. the truck has 52,000 miles. and until this point i have had no issues with the engine or other drive components. Does anyone know what is wrong with my truck? all replies are greatly appreciated ben |
sounds to me like you were in limp mode
but its hard to tell. the dealer can pull codes from your computer, thats why we have a 5yr/100,000 mi warranty
Re: Sputtering!!!
My friend checked the codes for me before I went to the dealership. The codes were saying there was a problem with the PCM. The dealership told me depending on what exactly is wrong will determine whether it is covered under the warranty or not.
Re: Sputtering!!!
The PCM should be covered, but the dealer would never, ever tell you over the phone you are covered under warranty, unless the car was really new.
Re: Sputtering!!!
It sound like you are still under warranty, why not just have a good dealer look into:shade: it???
Re: Sputtering!!!
If Ben is still reading the forum -
When your wife experienced this issue - what was the weather like? Lots of snow or rain at the time - or had the weather been clear? |
Re: Sputtering!!!
Same thing happened to me last year:(. I took it to the dealer, they fixed. I can not remember the fix, but was something very easy. Never happened again:D
Re: Sputtering!!!
My issue turned out to be a cut wiring harness that was shorting on the frame. Driving through a big snowstorm exacerbated the issue.
