Preventative Maintenance
I'm at 135K miles(original owner) and I wanted to hear what preventative maintenance everyone else would do at this point to make it another 100K+ miles? I will chime in with what I have already done but I wanted other opinions.
https://www.greenhybrid.com/forums/m...9-dscn3682.jpg |
I did a complete fluid change in my previous hybrid. OEM tranny oil, OEM transaxle fluid, differential fluid, coolant, brake fluid, etc.
Re: Preventative Maintenance
Originally Posted by evois
(Post 258739)
I haven't done the Brake fluid yet being is super dry Arizona(Brake fluid is hygroscopic , which is why it needs to be changed), I think I may change the brake fluid soon anyways. I also did the spark plugs & wires at 100K, and changed both motor mounts(they were shot). I also replaced the oil pan gasket and trued the oil pan(it was seeping ever so slightly & appeared to be cockeyed from the factory), and because I had to remove the auxiliary transmission pump to get the oil pan off, I changed that too(I didn't like the way it looked and I didn't want any issues) |
