Noise from transmission during hot start
Hey all, my Tahoe has been making an awfull noise when it starts up when the car is all warmed up. It won't do it on a cold start or if the trans temp is less than about 130. Above that when it starts or is starting up the engine coming out of auto-stop it makes a really bad noise. It's kind of like a groaning/grinding combination from the transmission. Since this started I have had the jerky start and jerky braking into auto-stop each. As far as I know the car is up to date on programming, and this is something that recently popped up (since the dealer replaced the trans fluid pressure regulator spring for slipping in gear).
Has anyone had something like this happen that I can point the dealer into the right direction? Unless it's a hybrid part I'm out of warranty, so I'd rather have it pretty much diagnosed before spending too much to fix it. |
Re: Noise from transmission during hot start
I get a whining noise sometimes from the auxiliary pump when I am in Autostop mode, just behind the brake paddel. you can hear it loud from the outside of vehicle.
once the engine starts the noise disappears. Thats teh only sound I get ocasionaly |
Originally Posted by kkelley
(Post 237172)
Has anyone had something like this happen that I can point the dealer into the right direction? Unless it's a hybrid part I'm out of warranty, so I'd rather have it pretty much diagnosed before spending too much to fix it. I am hoping that replacing the pump will fix both those issues for me! |
Doubt if the OP will be back, it looks like he got rid of his Hybrid 4-12-2012 by his last post. The worst thing about having one of these GM Hybrid TwoMode vehicles is the total lack of expertise out in the market place.
I see nothing wrong with raising a dead thread, maybe someone has solved the issue and can chime in. |
| All times are GMT -7. The time now is 12:17 AM. |
