Excessive play in driver seat
i'm a proud new owner of a 2009 Yukon Hybrid and i LOVE it. It gets much better MPG than my silverado, but then again my Silverado has over 450hp/500tq, gas saving is the last thing on my mind when i drive that.
Anyway, i didn't notice the seat when i test drove the vehicle, but now after a few hundred miles i'm noticing that the driver side seat has some excessive play. When i accelerate quickly it will "shift" backwards, a hard stop it will "move/shift" forwards and sometimes "click", also hard turns left or right will cause the seat to shift in the opposite direction (centrifugal force). I tightened down all the bolts, but no luck. A search on the internet showed that older Chevy and GM trucks had an issue where the shims fell out of the track causing seat shift. i couldn't find anything recent. anyone else run into this issue? i'm hoping my extended warranty will cover the repair and just give me a new seat. |
Re: Excessive play in driver seat
yes! have it fixed. it is a safety issue.
Originally Posted by evois
(Post 254882)
can you elaborate? did you have the same issue? what caused it? what fixed it? |
Originally Posted by IslandCre8tion
(Post 254884)
is that a "yes" you're familiar with it? or "yes" you agree it's a PITA. can you elaborate? did you have the same issue? what caused it? what fixed it?
(Post 254880)
I'm a proud new owner of a 2009 Yukon Hybrid and i LOVE it. It gets much better MPG than my silverado, but then again my Silverado has over 450hp/500tq, gas saving is the last thing on my mind when i drive that.
Anyway, i didn't notice the seat when i test drove the vehicle, but now after a few hundred miles I'm noticing that the driver side seat has some excessive play. When i accelerate quickly it will "shift" backwards, a hard stop it will "move/shift" forwards and sometimes "click", also hard turns left or right will cause the seat to shift in the opposite direction (centrifugal force). I tightened down all the bolts, but no luck. A search on the internet showed that older Chevy and GM trucks had an issue where the shims fell out of the track causing seat shift. i couldn't find anything recent. anyone else run into this issue? I'm hoping my extended warranty will cover the repair and just give me a new seat. I have had this issue in my 2009 Hybrid Tahoe since practically day one if the seat is all the way back and all the way down, by moving the seat a hair forward and a hair up the seat stabilizes for the most part. I had the seat replaced under warranty early on and the issue returned almost immediately, thank god warranty paid for the insanely costly seat which solved nothing. |
Originally Posted by hybrid-theory
(Post 254886)
The Seats in the Hybrid are definitely less robust than in it's non-hybrid counterpart, most likely to save weight. I have had this issue in my 2009 Hybrid Tahoe since practically day one if the seat is all the way back and all the way down, by moving the seat a hair forward and a hair up the seat stabilizes for the most part. I had the seat replaced under warranty early on and the issue returned almost immediately, thank god warranty paid for the insanely costly seat which solved nothing.
The Esky and Denali are luxury models and had power rear gates, running boards, and other similar content to non-hybrids.
Standard Tahoe and Yukons had the lighter different seats. |
(Post 254890)
I'm sure it's the same seat.
(Post 254894)
Standard Tahoe and Yukons had the lighter different seats. I drove the Yukon XL and the Hybrid Tahoe on the same day for several months and the difference was very noticeable. I actually considered finding an Escalade/Denail at the bone yard to switch out the driver seat but then realized it wouldn't be close in matching the rest of the seats, changing them all out would be prohibitively expensive, even from the bone yard. |
sounds like it's a common problem. i'll still have the dealer look at it, under warranty of course, and best case scenario is i get new seats without issues. I'll try moving the one i have no around a bit and see if it can tighten up.
thanks all |
