ABS Taction control lights
Please tell me someone know what is causing this. There is so much different info from wheel sensors to brake bleeding
Dealer is telling me ABS control Module is bad $2200 installed im sick any input? |
Re: ABS Taction control lights
Do you get the ding ding ding ding chimes and all sorts of lights too?
Do the door locks and instrument cluster glitch? If yes, known wiring issues in 2008s can do this. Does the brake pedal get real hard to push? If NO, what codes? Before you pull the lever on a brake module, make absolutely sure they can actually get their hands on one. |
Hillbilly,
Thanks for your response. No dings or chimes locks good no other lights brake pedal is hard to push down. code is c1121 |
Did the dealer try the Re-Learn procedure per diagnostic Circuit/System Verification?
They would probably charge at least 1 hour for it but they would have scan tool data. |
