2008 Yukon Hybrid A/C Noise
My wife has a 2008 Yukon Hybrid that makes a loud noise whenever it is humid/hot outside and the A/C is turned on. if you turn the A/C off and back on it will go away for a short period of time. It does not do it when the vehicle is in Auto Stop, only under gas power. Any suggestions?
Thanks in advance. |
Re: 2008 Yukon Hybrid A/C Noise
no noise here. can you take a video clip?
Its very hard to duplicate at it does not do it when the vehicle is stopped.
On hot and more particularly humid days the A/C compressor will work the hardest. With engine running it will run and cool harder. In Auto-Stop the compressor will back down a little. The reason? Noise.
The compressor is mounted on the right front lower engine block just like the belt drive non-hybrid. So it will be more noticable at the right front wheel well. It sounds normal to me. |
Is there a way to reduce or eliminate the noise? It can get pretty loud. Embarrassingly loud at times.
If you want to be warmer in the cabin... unless there is something wrong with the compressor.
I like the static and electrical sounds of the hybrid.
Here is the noise when it is not that loud. I captured this during remote start. It gets way louder than this.
https://onedrive.live.com/redir?resi...t=video%2c.mp4 |
sounded very normal to me....
This was the only TSB I found on A/c Noise
- Date: May 13, 2009 Subject: EI09115 - Poor A/C Performance, A/C Compressor Noise (Engineering Information) Models: 2009 Cadillac Escalade Hybrid 2008-2009 Chevrolet Silverado Hybrid, Tahoe Hybrid 2008-2009 GMC Sierra Hybrid, Yukon Hybrid Attention: Proceed with this bulletin ONLY if the customer has commented about this concern AND the EI number is listed in GMVIS. If the customer has not commented about this condition or the EI does not show in GMVIS, disregard the bulletin and proceed with diagnostics found in published service information. THIS IS NOT A RECALL -- refer to Service Bulletin 04-00-89-053B for more detail on the use of Engineering Information bulletins. Condition Important If the customer did not bring the vehicle in for this issue, DO NOT proceed with this bulletin. ONLY CONTACT THE ENGINEER IF THE DIAGNOSIS LEADS TO AN A/C REPAIR. Some customers may comment that the vehicle's A/C is not cooling or is not cold enough. Also, the customer may comment that the compressor is noisy when the A/C is turned on or engaged. Instructions Important DO NOT replace the AC compressor. GM Engineering is attempting to determine the root cause for numerous "No Trouble Found" compressor returns due to insufficient cooling or noise concerns from the customer. Engineering has a need to gather information on vehicles, PRIOR to repair, that may exhibit cooling or noise concerns. Document the following information on the repair order: For compressor noise, please confirm: 1. The correct refrigerant charge amount. 2. The compressor attachment bolt torques. 3. The high and low side refrigerant pressures. For compressor performance concerns, please confirm: 1. The 12 Volt fuse condition. 2. Identify all diagnostic codes that are set. 3. If B101D code is set, clear code and check A/C performance. Once the above has been documented and confirmed and the condition does not result in acceptable A/C compressor operation, please contact the Warranty Manager before continuing with compressor replacement. If the Warranty Manager is unable to return the call within two hours, proceed with the diagnosis and repair based on information found in SI. |
| All times are GMT -7. The time now is 03:31 AM. |
