2009 chevy silverado "service hybrid system"
I have a 2009 chevy hybrid mode 2.
last night the truck ran fine, in the morning it wouldn't start. There is a "Service Hybrid System " indicator light on now. I changed the 12v battery, checked fuses and checked voltage from the hybrid batteries, they total 309v when i checked them. What could be the issue? |
Re: service hybrid system
The issue is cross posting the same thing in 3 different places.
The next issue will be you responding to the above. |
(Post 271729)
The next issue will be you responding to the above. Do you really think that is the problem? 🤷♂️ If you can't be helpful just stay quiet. |
Re: 2009 chevy silverado "service hybrid system"
Originally Posted by Gilreath
(Post 271726)
last night the truck ran fine, in the morning it wouldn't start. There is a "Service Hybrid System " indicator light on now. I changed the 12v battery, checked fuses and checked voltage from the hybrid batteries, they total 309v when i checked them. What could be the issue? pull the codes a cheap OBD2 might be able to get the code from the freeze frame data |
| All times are GMT -7. The time now is 12:31 AM. |
