Electric Vehicle Forums
-   General Motors Corporation (https://electricvehicleforums.com/forums/general-motors-corporation-62/)
-   -   oil pressure gauge question (https://electricvehicleforums.com/forums/general-motors-corporation-62/oil-pressure-gauge-question-32524/)
dlnelsonroca Dec 31, 2020 07:36 AM
Hello! I just have a question. When my car is idling or running in the electric mode the oil pressure gauge is at zero. When running with the gasoline part it's fine. Is this normal, or should the oil pressure be showing above zero at all times? Thanks for your help.
dlnelsonroca Dec 31, 2020 09:20 PM
Re: oil pressure gauge question
I should mention that there are no codes.
Tahoe_08 Apr 8, 2021 05:28 PM
that is normal when it's in "AutoStop" the oil should read Zero according to the user manual.. the engine does not have an AUX pump like the transmission does
sepmaret11 Dec 24, 2025 09:36 AM
Keep in mind "delete" and "disable" is two different things. Deleting would mean switching out the cam, lifters and valley cover to completely rid the engine of the AFM systems mechanical aspects. There's probably other things that need to be switched out as well but not too familiar with the entirety of the process.
