Electric Vehicle Forums
-   Ford Motor Company (https://electricvehicleforums.com/forums/ford-motor-company-61/)
-   -   Do failed battery blend doors always throw a code? (https://electricvehicleforums.com/forums/ford-motor-company-61/do-failed-battery-blend-doors-always-throw-code-31005/)
08escapehybrid 11-10-2016 06:24 PM
I am getting symptoms of my car that lead me towards the blend door or maybe the thermistor or wiring harness of the battery. It seems like the battery will be getting cold or hot at times because the assist is low and it just wants to rev wildly when it hits even the slightest hill. Sometimes it will go to 4k almost immediately on what I guess would be about a 2% grade if that. I have never gotten any codes, it almost always gets poor mileage, but sometimes it will randomly get what it used to which was 31mpg at 70mph cruising on the highway. Lately I am looking at 25 on a good day and 22 on a bad one. That is with the engine fully warmed up on relatively flat ground resetting the gauge once I'm at cruising speed for a while.
Alisad 04-04-2020 02:24 AM
Re: Do failed battery blend doors always throw a code?
Hello folks!! I bought a substitution atmosphere control from LKQ on eBay on the grounds that my backdrop illumination had went out, however since I have it introduced the entryways that ordinarily open/near direct wind stream don't appear to work any longer.
snaptube vidmate
