XGAUGE AWD Indicator
Wonder if we could find the PID for the Torque reading so we would know how much torque is being requested to the rear.
Some outputs of the 4WD control module are: • solid-state clutch (pulse-width modulated signal) • 4WD indicator received by the instrument cluster. • percent of torque transfer commanded signal to the PCM. • torque request available signal to the ABS. |
Re: XGAUGE AWD Indicator
There are many PIDs available from the AWD module, but since I don't have one to test, I can't verify what they are or what the scaling, etc. is. Also, xgauges can be made to monitor the actual bus traffic instead of requesting PIDs. Again, I have no way to test these. My previous attempt at the AWD engaged xgauge didn't work out too well.
